2.8 CRD Sludge in water - JeepForum.com
post #1 of 10 Old 05-05-2014, 05:05 AM Thread Starter
Reeflodge
2005 KJ Liberty
Anyone know why I have a cream coloured sludge in my water reservoir?
Paul Woodman
www.fredwoodman.co.uk
Reeflodge is offline
post #2 of 10 Old 05-05-2014, 05:55 AM
jp7794
2006 KJ Liberty
It is normal for HOAT coolant to do that. If you want to clean the tank, pull it and clean it with Prestone Super flush.
jp7794 is offline
post #3 of 10 Old 05-05-2014, 05:12 PM
95BadBoy
That really does look crappy.
It looks like a full flush and cleanup is in order. I have not seen one look that gunky before.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #4 of 10 Old 05-05-2014, 08:10 PM
oilbuner
2006 KJ Liberty
I've never seen that before Flush that OUT…..
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #5 of 10 Old 05-06-2014, 12:36 AM Thread Starter
Reeflodge
2005 KJ Liberty
Is there a Sticky on how to flush out the cooling system?
Paul Woodman
post #6 of 10 Old 05-06-2014, 05:52 AM
Billwill
2002 KJ Liberty
The CRD section at lostjeeps has a fair amount of info on how to flush out the system.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #7 of 10 Old 05-06-2014, 04:43 PM
monduk
2004 KJ Liberty
Its a straight forward job, dropping the old coolant , undo the radiator plug, take off the lowest coolant hose at one end.> replace fluid with >> eBay item number:
271319980161
when only the best will do "
monduk is offline
post #8 of 10 Old 05-07-2014, 04:07 AM Thread Starter
Reeflodge
2005 KJ Liberty
271319980161
3.7lt @£60 I would need x4 of those to refill my coolant thats £240!!!!!
I think a 5year Ethlene Glycol will be OK @ £18 for 10lt at Eurocarparts will do the job!
What you describe above is just to drain the system I need to flush out that sludge!
Paul Woodman
post #9 of 10 Old 05-07-2014, 05:14 AM
Billwill
2002 KJ Liberty
Is this Ethylene Glycol HOAT?....I cannot find this out on Google
Make sure you only use HOAT antifreeze or major damage will occur
Billwill is offline
post #10 of 10 Old 05-07-2014, 05:00 PM
95BadBoy
I would concur with Billwill. It really needs to be HOAT, not regular plain old ethylene glycol. This is an item you don't want to skip or substitute on at all.
95BadBoy is offline
