2.8 crd problem - JeepForum.com
post #1 of 10 Old 07-04-2012, 01:43 PM Thread Starter
davidpals
2004 KJ Liberty
2.8 crd problem
hi guys - i posted earlier but in the wrong section me thinks .
when driving home from work today , on an up hill the jeep cut out completely - as if you had turned off the ignition . then selected park ignition off then back on - it started up and drove until it did it again a couple of times - maybe 1/2 mile between . no dash warnings or anything .
got home replaced diesel filter and away again - after the air had gone -took it for a test - after probably 2 miles same again - i am completely at a loss - any ideas what to try next ?? it looks like i gotta go to work in the landy tommorrow -- heres hoping for a solution
cheers dave p
davidpals is offline
post #2 of 10 Old 07-18-2012, 02:04 PM
sapoliberty
Hi, i was wondering if you got this solved. My guess would have been fuel filter/air in fuel. So in short, I'm no help. Just curious.
sapoliberty is offline
post #3 of 10 Old 07-18-2012, 03:59 PM
Bob_Farley
Check the CPS (Crank Position Sensor). It will through a code but not trigger a check engine light. Basically it will run like a champ until it gets hot and the sensor malfunctions.
If it's the CPS it is located on the lower passenger side of the engine about half way up the crank case...you will need to remove the turbo down pipe to change it out...I've heard of people changing without removing the down pipe but I don't see how it can be done without a monkey.
Bob_Farley is offline
post #4 of 10 Old 07-19-2012, 01:14 AM
Billwill
2002 KJ Liberty
It is actually the Driver side on Davids RHD UK model
I have sent David some information and he has pulled out a P1130 code...which may or may not be relevant. This refers to problems on the Fuel Pressure Rail side but the CPS has also been touted as a possible problem
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #5 of 10 Old 08-26-2012, 07:12 PM
Tulmaster
2005 KJ Liberty
Hello, Just joined JF in the hopes that someone here might be able to offer additional insight into the problem with my 05 2.8 liberty CRD with 80k miles. I saw Davidpals thread and thought it sounds much like mine which is also heat related. Runs fine cold but as soon as it warms up it goes to limp mode. My codes are the P0093 code for positive fuel pressure deviation or other wise large fuel leak. I am posting all the information on what it does and does not do in my own thread, but my question here is more as to why the cam sensor (or any other sensor that may cause a problem such as described here) is not throwing a code if it is or can be responsible for the problem?
Tulmaster is offline
post #6 of 10 Old 08-27-2012, 01:24 AM
Billwill
2002 KJ Liberty
Either the crank sensor or the cam sensor can cause this problem of not starting when hot.
As to why no code is posted.....lazy programmers at Chrysler who ran out of interest. Green Diesel Engineering are apparently looking into this to see if they can fix this issue in the ECM/PCM tunes that they do.
Billwill is offline
post #7 of 10 Old 11-17-2014, 03:37 PM
rkcustoms
how do you get to the cps on a 2.5 crd model
rkcustoms is offline
post #8 of 10 Old 11-18-2014, 11:13 AM
Bob_Farley
It's located on the passenger side...from underneath follow the down pipe from the turbo up about midway on the block. You'll need to remove the down pipe from the turbo to access. It's almost accessible without removing but down pipe but you'll need long arms and small hands to remove CPS sensor. Be careful when removing the sensor not to break off the potion in the block.
post #9 of 10 Old 11-19-2014, 12:31 AM
Billwill
2002 KJ Liberty
rkcustoms live in the UK so what you call the "Passenger side" is the "Driver's" side to him!
Billwill is offline
post #10 of 10 Old 11-20-2014, 04:19 PM
synthetic-oil
2006 KJ Liberty
Go to: http://www.lostjeeps.com/forum/phpBB...9b2d7e523b4428
More CRD info there
06 KJ CRD 545RFE, AMSOIL Oil & Filter
48 T4 Willis Pickup
93 C3500 Chevy 6.5 Turbo Diesel
84 C7500 Chevy Flat Bed 366 gaser
synthetic-oil is offline
crd , problem
New KJ and one problem wrw712 KJ Liberty Forum 16 02-29-2012 07:57 PM
2 Hi problem madmacks61 KJ Liberty Forum 3 11-28-2011 06:45 AM
air problem tjguy26 KJ Liberty Forum 1 01-09-2010 07:52 PM
Has anyone had a problem like this Daves'04rubi KJ Liberty Forum 3 11-18-2007 07:22 PM
RB1 GPS problem LIYANG KJ Liberty Forum 2 08-19-2005 10:01 AM
