15" Rims & Tires for 2004 Liberty? - JeepForum.com
post #1 of 4 Old 12-25-2010, 03:37 AM Thread Starter
Nilknarf
2004 KJ Liberty
Hey guys,
I have a few questions and was wondering if anyone could help me out. I'm currently using the stock rims and 235/70/R16 tires on my 2004 Liberty. I'm planning to replace them with 15" rims, but I'm not sure if they'll fit properly (and not rub up against and/or interfere with the brake calipers).
I'm considering purchasing the 15" Black Rock Series 916 Steel Wheels with 5x4.5 Bolt Pattern. I've heard some people say that the Liberty needs 4.5" of backspacing when fitting a 15" rim. My issue is that I can only find this rim in either 15x7 with 4.25" of backspacing or 15x8 with 4.75" of backspacing. Am I better off getting the rim with 4.75" of backspacing?
And...what size tires do I need to get to fit these rims? I would like to stick get tires that have the same width and height I'm currently using.
Thanks for your help, guys. I appreciate any advice anyone would be willing to provide.
Nilknarf is offline
post #2 of 4 Old 12-25-2010, 05:04 AM
Turbobearcat
2015 KL Cherokee
My question is why are you going with 15 inch and not 17's?
Turbobearcat is offline
post #3 of 4 Old 12-25-2010, 09:31 AM
tjkj2002
2002 KJ Liberty
Better tire selection and cheaper tire selection,also generally just better for offroad as more sidewall makes for better traction when aired down.
To the OP............
get the 4.25" BS ones but get the 7" wide versions as the 8" wide rims will be to wide.You will have rub unless you have a lift,major rub with the 8" wide rims and no lift.
tjkj2002 is offline
post #4 of 4 Old 12-27-2010, 05:31 AM Thread Starter
Nilknarf
2004 KJ Liberty
Thanks for your feedback. Am I better off getting a 16x7 wheel with 4" of backspacing? Would that fit without installing a lift? I'm considering The Black Rock 941.
Thanks again.
Nilknarf is offline
2004 , liberty , rim , tire
2004 Liberty with "Part Time" lighting problems basenjidaddy KJ Liberty Forum 3 03-07-2010 02:56 PM
"Knocking" sound in 2004 Liberty gcotterl KJ Liberty Forum 2 02-03-2010 02:31 PM
2004 Liberty Handle Removal on "A" Pillar Question RGLiberty KJ Liberty Forum 1 01-06-2009 09:38 AM
2004 Liberty Limited Alloy Rims rcfremontsd KJ Liberty Forum 0 09-17-2004 06:18 PM
15" Rims/30" Scorpion Tires on Liberty? nautical_boy KJ Liberty Forum 8 09-09-2004 12:25 PM
