15" Rims/30" Scorpion Tires on Liberty? - JeepForum.com
post #1 of 9 Old 09-07-2004, 08:49 PM Thread Starter
nautical_boy
I have a 1991 Jeep Cherokee with 15"rims and 30"scorpion tires. I want to put them on my new 2004 Jeep Liberty? Is this possible? I just tried 5/16" spacers and they will not work...
Can I order aluminum adapters to bolt on then bolt the rims to them? Is this possible??? Will the tire fit? Will they scrub at all? I believe they are 9.5 in width...??? HELP???
nautical_boy is offline
post #2 of 9 Old 09-08-2004, 03:42 AM
madrabbitt
madrabbitt's Avatar
um. i think the primary problem would be lack of clearance for the brakes. thats not something a spacer would fix.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #3 of 9 Old 09-08-2004, 08:20 AM
4Factor
4Factor's Avatar
Unless of course you spaced the wheel out SO far that the brakes were no longer inside the wheel. If you decide to do that, the wheels better be Daytons else it won't fit the image. Oh and you'd better get a copy of Reel 2 Reel's "I like to move it"... gold chains wouldn't be a bad idea either.
All kidding aside, 15" wheels won't fit on a KJ. the brakes will not fit inside a 15" wheel unless you shave the caliper to make it smaller. It's apparently been done, but I wouldn't trust that. Brakes aren't something I'd feel comfortable messing with. I'm sure your insurance would be voided if they ever found out about that mod!
4Factor is offline
post #4 of 9 Old 09-08-2004, 12:37 PM
h_2_o
there is a similar discussion going on over at jeepsunlimited.com with pretty much the exact same thing. However some seem to think thre is a set or two that would work out there. considering there are hundreds of different 15" rims out there currently, the odds that there is a set that fits with some normal backspacing is likely. when someone runs across this rim let us know.
h_2_o is offline
post #5 of 9 Old 09-08-2004, 01:55 PM
valvestem
valvestem's Avatar
15" rim on Liberty
Good info 4Factor. A friend of mine who works at a 5 star dealer in southern Maine was under the impression that my 15" 96 jeep alloys would go on my 03 Liberty, but I had to tell him no way Jose with info learned from this forum. I hate to let the factory alloys go with the sale of the old 96, but that's the way is is.
valvestem is offline
post #6 of 9 Old 09-08-2004, 08:47 PM
h_2_o
actually tonight i tried 5 different sets of 15" rims on a kj. 4 of them there was no way that they would fit like everyone said the caliper was in the way. however on one of the rims i had, it had a 2" backspacing and the extra room that the backspacing gave the rim allowed it to barely fit. i still wouldn't be comfortable with it that way but it did show me that there is something definately out there that should fit. i imagine if you had a descent rim with only 1.5" backspacing you might be able to get around it, but then again i might be wrong.
h_2_o is offline
post #7 of 9 Old 09-09-2004, 10:19 AM
4Factor
4Factor's Avatar
I'm dying to know, and I'm sure a few others here are as well so please answer this.
What's the obsession with 15" wheels? Is there some reason people try to cram them on a Liberty. Personally I think they'd look WAY too small and, at best, look odd. I really don't think that 15" wheels give you any more tire choices, so unless you're looking to get more sidewall, what's with all this talk?
4Factor is offline
post #8 of 9 Old 09-09-2004, 10:47 AM
SpiffBoy
I was looking at them for the tire choice. Some tires are available in 15" that are a smaller OD (and thus can fit with only a 2.5" lift) then what's available in 16"
The other idea is, my CJ has 15" rims. If I get larger tires for it, then the "old" tires can go on my KJ. A set of 15" rims are by far less costly then new rubbers.
SpiffBoy is offline
post #9 of 9 Old 09-09-2004, 01:25 PM
h_2_o
right now my interest with it is basically the fact that i'm getting rid of my xj and have a few sets of tires with lots of meat left and rims and really didn't want to have to get rid of them. so that's the reason i personally was curious.
h_2_o is offline
'09 Jeep Liberty w/2.5" lifts and new tires unclejjg KJ Liberty Forum 8 03-16-2009 07:10 PM
2008+ Liberty Owners can now select "KK Liberty" as your "model" on this forum MtnLuvr KJ Liberty Forum 2 02-01-2009 09:22 AM
Wrangler 16" rims fit on 07 Liberty Limited oaklane KJ Liberty Forum 4 11-13-2008 11:08 PM
08 Liberty - biggest wheel/tire package - "street jeep" jbpdog KJ Liberty Forum 3 03-30-2008 04:05 PM
Rubicon Rims/Tires On A Liberty? superubicon KJ Liberty Forum 17 07-21-2006 11:23 AM
