100,000 mile checklist??? - JeepForum.com
post #1 of 9 Old 05-22-2012, 07:15 AM Thread Starter
jklanier84
2002 KJ Liberty
Hey everybody,
So here's the deal:
I've had my 02 Lib about six months and love it. But its pushing 110,000mi and i need to know what i need to do as far as preventative maintanence and things that NEED to be upgraded.
Details:
2002 Liberty Sport 3.7L 4x4
new radiator, k&n filter
jklanier84 is offline
post #2 of 9 Old 05-22-2012, 10:37 AM
mikey1273
2006 KJ Liberty
Since its a gasser you don't have to worry about a timing belt since you have a chain.
I would look into doing a tune up, changing the serpentine belt, Radiator hoses, thermostat, cooling system flush, oil change and do tranny, diff, and transfer case fluids if they have not been done in some time or you don't know.
the belts and cooling system items are what cause most breakdowns on the road.
mikey1273 is offline
post #3 of 9 Old 05-22-2012, 10:51 AM Thread Starter
jklanier84
2002 KJ Liberty
It's got a brand new radiator as of three days ago. that was fun btw... the belt is brand new, oil change last week, K&N air filter yesterday.
while i had it apart i looked the hoses over and they look fine.
so that leaves tranny, dif, and transfer case fluids... anything else?
i was thinking about changing the plugs and adding the stock fog/driving lights in the bumper that the renegades have and/or the renegade roof light bar...
any tips on exhaust or smalll lifts? im thinking maybe an inch or two lift and a 'quiet-ish' cat back
post #4 of 9 Old 05-22-2012, 11:01 AM
tjkj2002
2002 KJ Liberty
Take K&N out and throw in trash,install $4 paper airfilter,that's the 1st thing that should be done,better filtration and cleaner oil that way.
tjkj2002 is offline
post #5 of 9 Old 05-22-2012, 11:17 AM
Mitchell420tj
This is a good thread lol I'm only 19 so when I get to have that many miles on my jeep ill have a checklist waiting lol
Mitchell420tj is offline
post #6 of 9 Old 05-22-2012, 01:14 PM
MoD
2005 KJ Liberty
yeah i am not a fan of the k&n at all but i do love my amsoil...but the $4filters arent bad
MoD is offline
post #7 of 9 Old 06-19-2012, 10:00 AM Thread Starter
jklanier84
2002 KJ Liberty
Okay just thought id summarize real quick.
At 100,000 mi. It would be smart to inspect the following;
Serpintine belt
Radiator hoses and coolant (flush if needed) (HOAT coolant only)
Water pump
Sway bar bushings
Ball joints
Cv joint boots
Driveshaft cv joint seals
Brake rotors and pads / drums and shoes
A/C refrigerant (r134)
Windshield wiper blades
And the following should deffinatly be done;
Change oil and filter
Change air filter (stock paper filter is best)
Change transfer case fluid (atf+4)
Change front and rear differential fluids (80w-90 gear oil)
Change thermostat
Change spark plugs (regular copper core is best) (do this every 25-30k)
Okay i think thats about it. Did I miss anything or put any incorrect info on my list???
02 Ironman KJ
"When you have a Jeep, you must do Jeep things."
post #8 of 9 Old 06-19-2012, 01:18 PM
tjkj2002
2002 KJ Liberty
Serpintine belt
Water pump
Sway bar bushings
Ball joints
Cv joint boots
Change thermostat
Just change the serp belt and tensioner(they do wearout also),and only use a Gates EPDM belt or the OEM EPDM belt('02 KJ).Then keep the old belt and tensioner as backups.
Even though HOAT coolant is "rated" for 5 years or 150k you really should change it by 3 years or 75k to keep problems due to coolant issues from occuring.
Change trans fluid and filters every 60k at least and use ATF+4 only.If you keep on a regular OCI for the trans it's best to have a flush done every 30k and new filter(s) every 60k.
Don't forget to flush the brake fluid,with aluminum parts in the system it goes bad sooner.Should flush out every 2-3 years at least.Brake fluid is one of the most neglected fluids in your vehicle but a major one for safety.Smae goes for the power steering fluid.
The last item is the PCV valve,should be changed every 60k but at $5 for one changing it often is cheap insurance.
tjkj2002 is offline
post #9 of 9 Old 07-10-2012, 07:38 PM
jopina7807
2007 KJ Liberty
Good to know! My Lib just hit 101k so I'll be looking to do some of this soon!
jopina7807 is offline
60,000 mile Service help bradbb2005 KJ Liberty Forum 6 12-05-2010 10:13 AM
30,000 mile maintenance gcotterl KJ Liberty Forum 5 12-19-2008 11:18 AM
20,000 Mile Towing Report Droopy KJ Liberty Forum 6 03-12-2007 09:12 AM
CRD good for a 130 mile a day commuter? HammerDown KJ Liberty Forum 9 08-11-2005 09:50 PM
Liberty 0-60 and 1/4 mile xxxflhrci KJ Liberty Forum 27 02-04-2004 11:23 AM
