08 Liberty - TPMS Failure - JeepForum.com
post #1 of 10 Old 04-07-2008, 05:33 PM Thread Starter
liberty_lurker
Has anyone else had their TPMS say that it failed, and all four tires have dashes beside them?
It happened on my way from work this evening, and I checked all four tires, and they are at 35psi. It has 750 miles on it.
Dealer time?
liberty_lurker is offline
post #2 of 10 Old 04-07-2008, 05:36 PM
Busch2fan
2008 KK Liberty
Not yet. Tire pressure is right on with the display. Veh only has about 1800 miles.
Busch2fan is offline
post #3 of 10 Old 04-07-2008, 06:26 PM Thread Starter
liberty_lurker
Well, I read the manual and searched the forum, no luck. I guess I'll drive it to work tomorrow, and if the light doesn't go off, and the tire pressure starts being monitored again, I guess it'll be time to take it in, this might be my earliest warranty repair on any vehicle I've owned, after just two weeks.
post #4 of 10 Old 04-08-2008, 02:13 PM
merlinTec
merlinTec's Avatar
Hi
Interesting has it started ok and have you had poor range with the remotes?
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #5 of 10 Old 04-08-2008, 06:49 PM Thread Starter
liberty_lurker
Well today I got in it, and the TPMS showed my pressure on the EVIC just as it should. No problems with startup, and I haven't noticed poor range on my remotes. I can open the doors from 25 feet or so.
Do you have an idea of what it might have been? Hopefully it was a glitch.
Where is the antenna for the wheel sensors?
post #6 of 10 Old 04-08-2008, 06:50 PM
Busch2fan
2008 KK Liberty
If I remember correctly from my manual the sending unit is in the value stems
post #7 of 10 Old 04-09-2008, 05:10 AM Thread Starter
liberty_lurker
Well, I didn't word my question very well, but yes, I know the sensor's transmitting antennas are the stems, but in my case, I was thinking there was a glitch with the receiver or its antenna because all of my tire pressures went blank, and the system said there was a TPMS failure, and the little tire icon started blinking, so I was wondering if anyone knew where the TPMS system's receiving antenna is.
I would think it is in the passenger compartment somewhere because the owners manual mentions that aftermarket window tint can cause the system to fail.
post #8 of 10 Old 04-09-2008, 07:36 AM
merlinTec
merlinTec's Avatar
HI
It's in the WCM (wireless control module) and is the same receiver for the remotes (hence my question). There is an issue with the WCM locking up and you get a none start issue (see JK wrangler forum a lot suffer from this) and with this you could get poor or no remote. The TSB is to replace the WCM not sure if this covers your fault or not without fault codes.
Regards,
Merlin
post #9 of 10 Old 04-09-2008, 09:04 PM Thread Starter
liberty_lurker
Thanks Merlin. Hopefully it won't happen again, but if it does, its off to the dealer.
post #10 of 10 Old 07-27-2012, 03:00 PM
MudPuppy7592
2008 KJ Liberty
Tire Pressure Monitoring system
My wifes Liberty shows ony one with dashes but after she drives for a couple of minutes it clears up and all four are registering.
MudPuppy7592 is offline
TPMS on 2006 Liberty? PedalToTheFloor KJ Liberty Forum 1 07-29-2009 08:28 PM
Liberty Sunroof Failure to Close madzoon KJ Liberty Forum 4 02-19-2008 02:13 PM
2002 Jeep Liberty / Cherokee: Steering Failure. geepster KJ Liberty Forum 15 01-24-2008 02:20 PM
Tpms Help & Oil Change 08KKJeepGrn KJ Liberty Forum 2 01-04-2008 06:25 AM
Liberty clutch failure chaser KJ Liberty Forum 0 09-06-2006 08:23 PM
