06 libby CRD won't crank - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 06 libby CRD won't crank
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 07-27-2013, 12:31 PM   #1
Pete M
1988 MJ Comanche
It did this a couple years ago and that time it turned out to be the little bar that goes inside the ignition switch was broken. so we started there this time. got it all apart and the little bar is still fine. tried turning the ignition switch manually and the Jeep cranked and fired! but then died a second or so later. tried again with the same result but the jeep died even quicker. a third attempt brought the same result and then nothing. no more cranking at all. So I figured it was a faulty ignition switch. replaced that today and still nothing. doesn't even try to crank. is there something else in the steering column I'm missing?
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email: petermontie@hotmail.com
ComancheClub.com/forums
Pete M is offline   Reply With Quote Quick reply to this message
Unread 07-27-2013, 07:13 PM   #2
95BadBoy
Pete
Are you getting full voltage at the starter? Yah, you probably already checked all ends of the cables - thought I'd throw it out there anyhoo. Have you had any transponder keys made recently? How old is the battery?
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded
FS or FT (2) JK Rubi 17" Moab Rims - really nice shape
Need JK Rear Spare tire bracket for project
95BadBoy is offline   Reply With Quote Quick reply to this message
Unread 07-28-2013, 03:56 AM   #3
Billwill
2002 KJ Liberty
If you have the SKIS system installed you must have the chipped key in the ignition while turning the ignition key with a screwdriver.
If you do have SKIS, the amber key light with a line through it should come on for a few seconds when turning ignition ON.
If it flashes at you....it is not happy with the chip in the key.
If it stays on all the time likewise you have a SKIS problem.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline   Reply With Quote Quick reply to this message
