'06 KJ windows not working *NOT the regulator problem* - JeepForum.com
post #1 of 9 Old 07-05-2013, 12:32 AM Thread Starter
BobFromCO
2006 KJ Liberty
My '06 KJ did something odd tonight: Right rear window went down, then wouldn't go up. All the other windows worked. Then the left rear wouldn't go down, then the drivers side front wouldn't go down. The only window working (right now, at least) is the passenger side front. The rear windows don't work with either set of switches.
All the windows except the driver side front have had the regulators repaired with aftermarket parts.
I checked the 40A fuse under the hood for the windows, and it checks good.
My guess is either 3 of the switches went bad all at once (what are the odds of that?), or there is a problem with the BCM. Everything else in the KJ seems to be working just fine (lights/HVAC/etc), so I wonder if the BCM is even the cause.
How do I know if its the BCM or switches? Is there a way to "reset" the BCM? Are there other fuses that control the windows?
Any ideas at all would be appreciated!
Thanks!
BobFromCO is offline
post #2 of 9 Old 07-05-2013, 05:16 AM
Billwill
2002 KJ Liberty
Thanks!
The Service manuals usually call for the Master Window Switch Panel up front to be replaced for problems like this.
You can download the 2006 Service Manual here, quite a large file, 144 MB:
http://www.colorado4wheel.com/manuals/Jeep/KJ
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #3 of 9 Old 07-05-2013, 06:55 AM Thread Starter
BobFromCO
2006 KJ Liberty
Thanks Bill! After posting this last night, I pulled the switch out, detected the faint odor of burnt electronics in it. I'll be headed to the parts store today.
post #4 of 9 Old 07-05-2013, 09:28 AM Thread Starter
BobFromCO
2006 KJ Liberty
So, I found a replacement master window switch ($100!) and it resolved the issue with both drivers side doors, but the passenger side rear still will not go up... any ideas, anyone?
post #5 of 9 Old 07-05-2013, 11:00 AM Thread Starter
BobFromCO
2006 KJ Liberty
More: When trying to diagnose this problem, I've had 2 40 amp fuses blow. One blew when the motor wasn't even connected and I was checking for voltage at the motor harness. I have been able to get the pass rear window motor to work up and down when applying 12 volts directly to the motor (bypassing the jeep wiring), but it will not work through the factory switches. It looks as though there is only one relay for all the windows, so I don't think I've got a bad relay. I'm really pulling my hair out with this.
post #6 of 9 Old 07-05-2013, 04:49 PM
jbarthol
2005 KJ Liberty
This happened with my Jeep. Directly under the drivers seat is a set of wires that controls everything, which on mine corroded causing all the windows to stop working. To get to them you need to take the seat out, and pull the carpet up. Hopefully it is something easy, and not this issue. Mine failed due to snow/ice melting, and soaking those wires. Troubleshoot, first before tearing everything apart to get to those wires though. Can be costly, if you go to a dealership.
jbarthol is offline
post #7 of 9 Old 07-05-2013, 06:16 PM Thread Starter
BobFromCO
2006 KJ Liberty
Thanks, Jesse... As it turns out the problem may be a lot simpler. When I applied voltage directly to the motor and it went up and down, it was without the window glass on the regulator. When the window glass was secured to the regulator, and voltage applied directly the window would go down, but either not go up, or struggle to go up (I finally got it all the way up). So, that particular motor is either weak, or the regulator or glass is binding on something. I replaced the 40 amp fuses (they're over $4 each!), and reassembled the door, leaving that motor unplugged until I have more time to mes with it.
I did call a few dealerships, and the motor isn't replaceable on it's own, but has to be replaced with the entire (weak) regulator, to the tune of $210-$230 (parts only).
Long story short: Window is up, it's not going anywhere, everything else worked, and I'm out (so far) around $115.
post #8 of 9 Old 07-06-2013, 04:51 AM
Billwill
2002 KJ Liberty
Try cleaning the window guide and spray a bit of WD-40 inside the guide on each side of the glass to make it easier for the glass to move.
Billwill is offline
post #9 of 9 Old 07-06-2013, 04:00 PM Thread Starter
BobFromCO
2006 KJ Liberty
Thanks, Bill. I was thinking of spraying it down with some silicone spray lube and see what that does...
