05 Liberty Popping out of first gear - JeepForum.com
post #1 of 4 Old 01-08-2011, 02:58 PM Thread Starter
dmblair
Hey all, I have an 05 with 3.7 6sp manual 120,000 Miles. Just wondering if anyone else has ever had a problem with it popping out of first gear when taking off slow (ie pulling out of a parking spot, or going through a drive through.) I've noticed it's starting to happen a little more and more. Kinda scares ya a little when you're not expecting it. First time it happend was when I was in a drive through and I swear I thought I got rear ended. It sounds horribe but I can put it right back in gear and away I go. Just wondering if anyone else has any thoughts on this. Thanks.
dmblair is offline
post #2 of 4 Old 01-09-2011, 06:33 PM
richd
2008 KK Liberty
First thing to do is check you shifting linkage for wear,and proper Adjustment.You could have a worn shifting fork,or internal problem.
richd is offline
post #3 of 4 Old 01-09-2011, 06:34 PM
RainyLake
2006 KJ Liberty
I have the same but '06 model, about 76,000 miles. I started having the same issue last fall, but not very often (maybe once a month so far). No idea what's causing it though. I've also noticed a lot of roughness in the stick when shifting into second when it gets significantly below freezing. I'm wondering if my transmission fluid is degraded or low, though - it's near the end of the recommended interval, and I noticed significantly smoother shifting after the last fluid change. This is a total guess, though!
RainyLake is offline
post #4 of 4 Old 01-11-2011, 06:43 AM
x99j
mine does this about once a year, and only for my wife. i have always thought that she didn't have it in first all the way? mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
looking for liberty manual or tail wiring diagram 2002 liberty afgd1 KJ Liberty Forum 1 10-08-2010 05:30 PM
Will a 2004 liberty bumper fit an 05 to 07 liberty metalhead KJ Liberty Forum 2 09-05-2009 06:39 PM
08 Liberty popping noise fk1022 KJ Liberty Forum 2 07-24-2009 08:20 PM
04 liberty popping noise in rear Bucyrus KJ Liberty Forum 4 12-09-2007 08:51 AM
Liberty Transmission and Transfer Case Question! Shopping for a Liberty! Polaris Junkie KJ Liberty Forum 3 09-27-2006 09:18 AM
