05 Liberty KJ Overheating - JeepForum.com
post #1 of 8 Old 09-30-2010, 06:33 PM Thread Starter
usserraga
2005 KJ Liberty
My 2005 Liberty suddenly overheated yesterday while stuck in traffic.
Although I live in North Texas it wasn't particularly hot (mid 80s F) but I got steam coming from underneath the hood.
Today I replaced:
- Thermostat
- Radiator Reservoir Cap
- Coolant Temperature Sensor
This is as much as I feel comfortable doing without a strong background in mechanics.
Still, after 20 min. idling it goes almost 3/4 of the gauge and I have to stop the engine. Same when I am driving it.
When I open the hood, I can feel the coolant boiling inside the hoses. No leaking visible.
Please, any pointers here will be greatly appreciated before I start throwing money at mechanics.
Thank you in advance!
Gabriel
usserraga is offline
post #2 of 8 Old 09-30-2010, 09:11 PM
richd
2008 KK Liberty
Today I replaced:
- Thermostat
Gabriel
Did you see your cooling fan kick in?Quick way to check is put on the A/C and the cooling fan should run.If not then you need to check relay,wiring,and connector at the fans.
richd is offline
post #3 of 8 Old 10-01-2010, 09:04 PM Thread Starter
usserraga
2005 KJ Liberty
Thank you for your quick reply.
Yes, the fan runs.
One question, though: Is the fan supposed to keep running even after turning the car off when the engine is still very hot?
Because it doesn't in my case.
I never put attention to this before so I can't tell whether this is a problem or not...
post #4 of 8 Old 10-01-2010, 09:18 PM
richd
2008 KK Liberty
Yes, the fan runs.
I never heard my KK or My Charger fans stay on after I turn them off.Thats with over 100* outside.Double check your coolant you might have air in system,a common problem when the stat is changed.What you can try is put your heater on full blast,let it run but not to hot.Let is cool off and double check your overflow tank.
richd is offline
post #5 of 8 Old 10-02-2010, 07:43 AM Thread Starter
usserraga
2005 KJ Liberty
Ok, will do that.
Not sure what I will be looking for, though.
Is the coolant level supposed to be low after that?
post #6 of 8 Old 10-02-2010, 01:08 PM
richd
2008 KK Liberty
Ok, will do that.
If you have air in the system,the overflow tank should be low.
richd is offline
post #7 of 8 Old 10-03-2010, 04:18 AM
bradbb2005
2008 WK
Maybe try a flush? sounds like you could also have a blockage somewhere preventing or limiting flow.
Current:
2008 WK Limited 5.7L HEMI
Mods: | JK Moabs | 245/70-17 General Grabber AT2 | 1.25" Wheel Spacers
2008 KK 3.7L V6
Mods: | 225/65-16 General Grabber AT2 |
bradbb2005 is offline
post #8 of 8 Old 10-03-2010, 07:05 AM
journeyjim
Junior Member
journeyjim's Avatar
2006 KJ Liberty
Sounds like the water pump isn't circulating the water, in a forum somewhere some one had a water pump that the impeller came off inside of the pump.
journeyjim is offline
2005 , liberty , overheat
05 Liberty CRD overheating??? Dieselgirl KJ Liberty Forum 12 11-09-2014 07:21 AM
Liberty Overheating asax08037 KJ Liberty Forum 10 07-03-2013 03:02 PM
2002 Jeep Liberty overheating feener KJ Liberty Forum 10 11-21-2010 03:58 PM
2002 Liberty Overheating jeff0218 KJ Liberty Forum 4 07-30-2010 07:57 PM
'02 Liberty 3.7L V6 Engine Overheating jrtbeau99 KJ Liberty Forum 2 07-18-2008 07:29 AM
