04 Liberty Won't Start--Clicking Noise? - JeepForum.com
post #1 of 18 Old 06-04-2008, 04:56 AM Thread Starter
JEEP97TJ
We have an 04 Liberty that as of yesterday afternoon would not start. It was driven around town yesterday morning, but after being parked for a few hours, would not and will not start.
The ignition can be turned to the ON, ACC positions, and the Lights, radio, etc work fine.
When the ignition is turned all the way, instead of the engine starting up, there is just a repetitive clicking noise. It sounds almost like a wind-up car when the ignition is turned.
It sounds to me like this is the Starter. The dash shows a blinking Check Engine Light when the ignition is turned on, after the normal pop-up icons dissappear.
Could disconnecting the negative lead of the battery cable help/ clear the possible code(s) for a while to see if it'll start?
Any help/advice is appreciated.
Blacksburg, VA
JEEP97TJ is offline
post #2 of 18 Old 06-04-2008, 07:39 AM
Jakked
Almost a sure bet that it's the battery.
2004 Liberty Sport 3.7L A/T 4x4 Cmd-Trc
Former 4x4s:
1999 TJ 4.0L I-6 4x4 5-Sp *Mods*
1986 Trooper 2.3L I-4 4x4 5-sp
Jakked is offline
post #3 of 18 Old 06-04-2008, 07:15 PM Thread Starter
JEEP97TJ
We tried to jump start it, but it didn't work. The battery may just be completely shot. The clicking noise sounds like a relay of some kind tripping on and off. I'm going to swap the battery from my wrangler into the liberty to try and isolate the problem.
Blacksburg, VA
JEEP97TJ is offline
post #4 of 18 Old 06-04-2008, 08:28 PM Thread Starter
JEEP97TJ
I swapped in the battery from my Wrangler, and the Liberty started right back up.
Any suggestions for a new battery for the Liberty?
Blacksburg, VA
JEEP97TJ is offline
post #5 of 18 Old 06-05-2008, 12:59 PM
richd
2008 KK Liberty
There are several brands,Diehard,Exide,Interstate.Get one with more cranking amps,then the stock one.
richd is offline
post #6 of 18 Old 06-05-2008, 01:55 PM
Jakked
I'm very partial to the optima yellow-tops. Or a red-top for that matter, but I like the deep-cycle option.
Former 4x4s:
Jakked is offline
post #7 of 18 Old 06-05-2008, 04:01 PM Thread Starter
JEEP97TJ
The optimas are way expensive. I got a red-top for my wrangler about 1.5 yrs ago, only because the yellow-tops were just that much more expensive. It has and is continuing to serve me well, but the Liberty didn't need that kind of battery. So, we went with an Autocraft battery from Advance Auto. It has a good warranty, and more CCA than the stock battery. Good to go.
Blacksburg, VA
JEEP97TJ is offline
post #8 of 18 Old 09-06-2013, 09:00 AM
TerryHawk
2004 KJ Liberty
Same problem
I actually have the same problem happening in my Jeep Liberty right now. I just bought a new battery and replaced the old one, but it still is not starting up. Any ideas?
TerryHawk is offline
post #9 of 18 Old 09-06-2013, 10:41 AM
jstraw
I sounds like its electrical... my 02 liberty has a flat copper bar (very thin) on the positive terminal connector, plus the positive terminal was corroded and flimsy, I cut the old terminal off leaving about 1-1/12 inch copper bar and bought a brass terminal replacement. Make sure your terminal connectors are clean... I have a corrosion problem with mine and every battery I put in my liberty ended with blue crystals covering the terminals, that stuff is extremely corrosive, if you have that, be sure to buy a can of terminal cleaner that turns pink whereever there is acid and clean it with a hose while your battery is out. Try climbing underneath and getting a good view of the starter, if there is gunk around it (old oil) that could be your problem. There should be a starter motor and a gear kicker on the side that pushes a gear forward, try tapping a hammer on the starter in different spots, don't dent it, but tap hard enough to kick foreign materials loose.
jstraw is offline
post #10 of 18 Old 09-06-2013, 06:20 PM
USPLiberty
I swear by these. I'm not sure how they work but I have never seen corrosion on my terminals with these felt pads on.
USPLiberty is offline
post #11 of 18 Old 09-07-2013, 04:11 AM
Billwill
2002 KJ Liberty
What exactly is your Jeep not doing....this is such an old thread it is best to start from scratch.
Does it turn over but not start?
There is a very common problem with the actuator pin that turns the ignition switch breaks off so you get ignition lights on but no power to the solenoid when you try to start it.
Some more details please!
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #12 of 18 Old 09-08-2013, 10:35 AM
TerryHawk
2004 KJ Liberty
When I turn the key over it makes a quick ticking noise, I have already replace the starter, which was terribly bad. However, it was my first time every doing that, so I'm not going to say that I knew what i was doing 100% it was mainly from YouTube. Also, it acts like it wants to turn over, but just never gets that extra energy. It has a half tank of gas, new starter, new batter, all electronics work. Idk what else.
post #13 of 18 Old 09-08-2013, 01:17 PM
mudd24
I have the same problem with my 07. It turns over but feels very weak. Some days it will start every time. But sometimes I will be stuck somewhere over 20 minutes trying to start it. The starter doesn't keep trying it turns once then that's it. Has only 75k and a new optima.
mudd24 is offline
post #14 of 18 Old 09-08-2013, 03:05 PM
1coopgt
2005 KJ Liberty
Check and make sure all battery connections are clean and tight . Also check connections to the Seloniod /starter .
1coopgt is offline
post #15 of 18 Old 09-09-2013, 12:36 AM
Billwill
2002 KJ Liberty
Also check the negative cable going to chassis is clean and tight and there is a grounding strap connecting engine to chassis....make sure that is clean and tight.
What happens if you remove the Starter Relay and jumper pins 30 and 87 in the relay socket...make sure you are in neutral!
This bypasses the interlocks on the starter relay such as Jeep is in neutral/park and bypasses the ignition switch and the Starter Relay....the engine should turn over.!!
If the engine does now turn over it means: Starter relay bad, interlocks bad or possibly the actuator that operates the ignition switch has broken...a common problem!
Billwill is offline
Clicking noise underneath Jeep Liberty 2003 sharhack KJ Liberty Forum 3 06-03-2010 04:22 PM
'03 Liberty Clicking w/ Wheel Rotation BubbaJane KJ Liberty Forum 4 06-03-2010 04:19 PM
03 Liberty No start bob55 KJ Liberty Forum 3 08-22-2009 10:52 PM
rapid clicking sound when start / stop engine rockymountain KJ Liberty Forum 2 06-29-2005 08:48 AM
Why oh why does My '04 Liberty not start??? NJinTX KJ Liberty Forum 8 01-25-2005 11:52 AM
