04 Liberty tail light problems - JeepForum.com
post #1 of 5 Old 04-19-2010, 03:24 PM Thread Starter
Adroc3905
Hi everyone,
I have searched the forum but was unable to find my answer so now I am posting it. I appreciate any and all help.
I recently (last fall) installed an aftermarket trailer hitch wiring harness that uses a piggy back type system from the left and right rear factory harnesses. It worked flawless until now.
Last week the Jeep left turn signal indicator inside the cluster would illuminate when I applied the brakes and the left brake and middle brake lights would flash when I used the left signal. I immediately assumed it was a crossed ground wire between the signal and brake lights at the harness so I unplugged the aftermarket trailer hitch piggy back system and reinstalled the factory harness as a temp fix. Now the driver’s front and rear parking lights do not illuminate at all but the cluster illumination when applying brakes and flashing during signal operation has stopped. The rear bulb is fine (although now that I think about it the front one has yet to be checked) as I tested it to be sure. Also the turn signal, brake and reverse work perfect. It’s simply the parking light feature for the entire driver’s side that is not operating now.
Rather than trace a chaffed or broken wire through thru numerous feet of Jeep I was hoping that maybe someone could recommend some other options I can exhaust first. I also checked the fuse box inside the Jeep. Here is the weird part. The 2004 owner’s manual states that fuse location #23 is the left parking light fuse. I immediately though awesome….easy fix. Well in my Jeep fuse location #23 is empty. There is not even prongs to accept a fuse into this location. So now I am baffled. Are there fuses under the hood that may be worth looking at? Anyone else have this problem?
Thanks
Adroc3905 is offline
post #2 of 5 Old 04-21-2010, 09:12 AM
Billwill
2002 KJ Liberty
There is a Sticky above called Liberty Service manual.
Download section 8, circuit diagrams (about 40 meg)
This is for the 2002 models,gas or diesel,local or export, LHD...RHD etc. but I think the basic wiring and harnesses will not have changed much for the later models.
It is in PDF format, keep it on your PC and print the pages you think are relevant...I find this extremely usefull!
Billwill is offline
post #3 of 5 Old 04-21-2010, 04:07 PM
T-birdJunkie
2002 KJ Liberty
This is directly caused by a trailer harness issue. Same happened to ThunderbirdJunkie's. He simply removed the harness.
T-birdJunkie is offline
post #4 of 5 Old 05-03-2010, 04:20 PM Thread Starter
Adroc3905
Removed harness completely, similar issue. Its not the harness causing this.
post #5 of 5 Old 05-05-2010, 05:09 AM
Billwill
2002 KJ Liberty
As I said two posts above, download the circuit diagram and use it or get someone with some electrical knowledge to use it to trace the problem.
Billwill is offline
Liberty 05 Tail light trailer wiring. drozenski KJ Liberty Forum 1 08-01-2009 04:25 PM
liberty tail light assembly...need help jvk06tj KJ Liberty Forum 3 05-12-2009 03:28 PM
tail light question (liberty 05 renegade) maximebeauvais KJ Liberty Forum 6 03-17-2009 05:40 PM
03 liberty Renegade Dash ligh/Right tail light morhaven KJ Liberty Forum 2 06-10-2008 12:23 PM
2008 Liberty tail light wiring Justjoe444 KJ Liberty Forum 1 05-24-2008 09:01 AM
