04 liberty sport, headlights, power windows, horn and cigarette lighter won't work - JeepForum.com
post #1 of 10 Old 10-29-2013, 04:52 PM Thread Starter
Brianpitera
2004 KJ Liberty
I just bought an 04 liberty sport, the power windows, low beams, cigarette lighter and the horn won't work. So far I have replaced the bulbs in the headlights and checked all the fuses and cleaned the contacts as well as cleaned up the ground on the top center of the fire wall. Are there. Any fuses I should double check or any grounds to specifically look at? Any help would be greatly appreciated!
Thank you!
Brian
Brianpitera is offline
post #2 of 10 Old 10-29-2013, 10:06 PM
HTDutchy
2007 KJ Liberty
Checked battery voltage and connections?
Ive seen a lot off problems caused by that
"Need tea == Need kitchen"
92 XJ Performance 4.0HO
07 KJ Sport 2.8 CRD
HTDutchy is offline
post #3 of 10 Old 10-30-2013, 01:50 AM
Billwill
2002 KJ Liberty
Thank you!
Brian
Have you checked the fuses under the hood and also on the fuse panel inside the cabin?
You can download the Service Manual here..includes the circuit diagrams...download the 2003 Service Manual...will be close enough to your 2004 KJ.
http://www.colorado4wheel.com/manuals/Jeep/KJ
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #4 of 10 Old 10-30-2013, 09:24 AM Thread Starter
Brianpitera
2004 KJ Liberty
Today I'm planning on unplugging the battery and cleaning the terminals really well as well as all of the grounds I can find, recheck and clean all of the fuses in both boxes and then check all of wiring harnesses. Crossing my fingers that it's a simple fix. Thanks for advice!
post #5 of 10 Old 10-30-2013, 04:41 PM
jbarthol
2005 KJ Liberty
Don't forget the relays under the steering wheel.
jbarthol is offline
post #6 of 10 Old 10-31-2013, 03:17 AM
Billwill
2002 KJ Liberty
Yes good advice...this is basically the panel that holds the fuses inside the cabin...the high beam relay is on the front while the other relevant relays are on the reverse of this fuse panel so this fuse panel needs to be pulled out and flipped over....the circuit diagrams at least identifies which relay is which as they are not marked on the panel...known as the Junction Block.
Billwill is offline
post #7 of 10 Old 10-31-2013, 09:15 AM Thread Starter
Brianpitera
2004 KJ Liberty
Thank you, is it connected to the fuse box behind the door or directly under the wheel?
post #8 of 10 Old 10-31-2013, 11:08 AM
jbarthol
2005 KJ Liberty
Basically it's the same panel, just the backside of the one by the door. To access it you will need to pull down the kick panel below the steering wheel. On my 05 Limited use a panel removal tool (or your own hands if your like me) to release the two clips holding it in place on the top of the panel. Mine is hinged on the bottom, so no need to bother with that end.
jbarthol is offline
post #9 of 10 Old 10-31-2013, 11:30 AM Thread Starter
Brianpitera
2004 KJ Liberty
Thank you so much, that will be tomorrow's project!
post #10 of 10 Old 11-02-2013, 10:12 PM Thread Starter
Brianpitera
2004 KJ Liberty
Fixed it! There was a red and yellow wire and blue wire under the good, in the corner closest to the steering wheel. Got them back together and no more problems. Thank you so much for the help!
