04 liberty several obd2 codes help - JeepForum.com
post #1 of 2 Old 06-09-2014, 02:09 AM Thread Starter
wvjeepman2014
i have a 04 liberty i put a 03 engine in it changed the refluctor ring and cam gear ring to make it work i now gotta have it retimed due to the front little primary chain being wore out stretched and the cam gears out of time?im getting a crank shaft position camshaft position corrlation code?also getting a knock censor code and a open injector circuit cylinder 1?the jeep will fire up n idel but will not take throttle could that be due to out of time or whats your opinon?this thing getting on my nerves someone please help me
wvjeepman2014 is offline
post #2 of 2 Old 06-09-2014, 06:18 AM
streetglideok
2005 KJ Liberty
Need to investigate the injector issue, as it sounds like it may not be plugged in or seated correctly. The correlation code, sounds like you need to pull the valve covers and timing cover off and recheck things and repair as needed. Measure twice, cut once is the rule.
streetglideok is offline
