04 Liberty Drivers Window Problems - JeepForum.com
post #1 of 3 Old 05-13-2012, 02:19 PM Thread Starter
MrPaul
2004 KJ Liberty
Greetings. On a O4 Liberty when I push the drivers front windows switch down the window does not stop at the bottom and I can hear the motor against the cable making a bad noise.
I have replaced the plastic window bracket with one of the metal ones thinking that was the problem, but no go.
Sometimes the excess cable that should be feeding through the motor comes up next to the window.
So how does the windows shut off automatically knowing it is at the bottom?
Thanks folks.
Paul
MrPaul is offline
post #2 of 3 Old 05-13-2012, 05:51 PM Thread Starter
MrPaul
2004 KJ Liberty
Okay, I think I have this figured out. The plastic main tube has broken about 6 inches out from the guide rail. Having never seen one before, I though this was normal. This would allow the spiral cable to escape out and push up next to the window where I could see it. Now the interesting question. Do I need to replace the whole friggin assembly or is there a place to purchase just the plastic tube? Or does anyone have any ideas about fixing it without having to purchase a whole new assembly?
I tried to hold it together while I activated the power to it while it was out of the window frame, and it seems as if there is alot of pressure, so my idea of using the infamous duct tape to hold it together quickly faded. Any ideas would be appreciated.
Paul
MrPaul is offline
post #3 of 3 Old 05-13-2012, 06:36 PM
95BadBoy
There was just a post quite similar to your problem within the last day or two.
LINKY
If you use the search function box at the top left, you will pull up a wealth of posts on the window regulator problem.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
Jeep Liberty Window Problems Solutions RocketQjQ KJ Liberty Forum 133 08-12-2015 07:52 AM
How to replace drivers power mirror 05 Liberty (help) jjr7040 KJ Liberty Forum 5 02-22-2011 12:02 PM
2005 Jeep Liberty Rear Drivers side window stuck/frozen evangwatkins KJ Liberty Forum 7 12-22-2010 10:02 AM
drivers window problem 04jliberty KJ Liberty Forum 1 08-29-2010 05:11 PM
04 Liberty Window Regulator Problems shakespearesdad KJ Liberty Forum 2 07-06-2008 08:04 PM
