04 jeep 3.7 runs rough at idle - JeepForum.com
post #1 of 6 Old 03-15-2013, 01:01 PM Thread Starter
budmcword
2004 KJ Liberty
Hi all, My jeep is running rough at idle and when trying to maintain a speed. Taking off it my hesitate for just a moment but then goes fine. its not until I easy off on the throttle and try to maintain a speed that it shakes and shutters or when I come to a stop. The jeep check engine light was on with a code P0300.
I changed the plugs, coil pack, ran some fuel injector cleaner, and even the catalytic converter ($$ not well spent there )
Let me rewind a little... When I changed the plugs the #6 cylinder had a bad plug. The plug was wet and was obviously not firing. This led me to believe, after changing the plugs and the problem remained, it was the coil pack. Once that was changed and the problem remained, I got flustered and did a crappy evaluation and said well its the cat.
So now the jeep is throwing several codes and runs the exact same. The code are p0300, p0302, p2302, p2305, p2308, p2311, p2314, and p2317.
Any thoughts on this Could it be the PCM?
budmcword is offline
post #2 of 6 Old 03-16-2013, 10:33 AM
oldfamilyguy
It could be the pcm, but look up all of those codes first to gain some understanding before randomly changing more parts. I believe they all relate to misfires and coils on more than 1 cylinder.
oldfamilyguy is offline
post #3 of 6 Old 03-16-2013, 11:19 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
All of the coil pack secondary circuits are showing an "Insufficient Ionization" error - and you have a general misfire code and misfires on cylinder #2.
There is something going on with the ignition system but beyond that I can't help you. Best take it to a shop that can put it on their scanner and look further to see if there is a fuel delivery issue and maybe run compression tests to check for valve train issues.
Post here when you get an answer.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #4 of 6 Old 03-16-2013, 11:46 AM Thread Starter
budmcword
2004 KJ Liberty
Thanks, the original code was only p0300. I looked that code up and did research using this site and others on what the problem(s) could be... None of the parts were randomly changed. You're right the code p0300 is related to a random misfire on more than one cylinder. I took it to a shop after doing all the work (Meineke) who can't figure it out either... I guess I need a better mechanic shop. Thanks for responding tho and I will let you know what it is when its figured out.
post #5 of 6 Old 03-16-2013, 11:54 AM Thread Starter
budmcword
2004 KJ Liberty
Bob
Thanks Bob, Your advice is well received and I'm ready to find a better mechanic shop than Meineke, lol. I took it there before posting and they couldn't figure it out. I will post up when I figure out the problem.
post #6 of 6 Old 03-16-2013, 02:09 PM
oldfamilyguy
Plugs, coil and cat. Just saying, try to diagnose first instead of wasting money on parts you don't need to replace. Although new plugs is never a bad idea I guess so long as thy're the correct ones. Good luck.
rough idle
