04 3.7L Liberty fluid amounts?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 04 3.7L Liberty fluid amounts??
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 05-12-2008, 07:32 PM   #1
the86project
I need to know for a 04 4x4 Liberty 3.7L v6:
1.How many liters is the manual transmission?
2.How many liters is the transfer case?
3.How many liters is the front and rear differential?
I had some trouble finding it in my Haynes and on the site because it just says fill to till pours out of fill hole. I am ordering the lubricants and need to know how much to order.
the86project is offline   Reply With Quote
Unread 05-12-2008, 08:13 PM   #2
rustym38a1
1953 M-38
Front axle is 2.6 pints or1.24L
Rear axle is 4.4 pints or 2.08L
Transfer case -Command Trac is 2.95 pints or 1.4L
Transfer case -Select Trac is 3.4 pints or 1.6L
Manual trans is 4.9 pints
11 Wrangler Rubicon JK "Call of Duty Black Ops Edition" 2 Door, all stock for now!
08 Liberty Limited KK- Sky Slider -Every option available at time (wife's car-off limits)
04 Sahara TJ- OME suspension, Borla Exhaust, Rusty's Skids, K&N, LED's, Pro Comp 31's
97 Wrangler SE- This is our Trail Jeep. Yukon 4.88's, Powertrax Locker, 32" BFG KM2 tires, XRC/8 winch
53 Willys M38a1- Restored w/50cal Browning M2HB & 53 M100 1/4 ton Trailer fully loaded with gear!
11 Liberty Sport KK- company car
rustym38a1 is offline   Reply With Quote
Unread 05-12-2008, 09:00 PM   #3
the86project
I am looking to replace the manual trans, front and rear diff, and transfer case fluids with Amsoil for my brother in law. I use Amsoil in my other vehicles and wouldnt suggest anything else. Does anyone have any suggestions which Amsoil products they use for the MTF, T-case and Diffs?
Unread 05-13-2008, 11:28 AM   #4
Ridin' Around
Here is the link to the application guide, simply plug in the specifics of the vehicle you are looking up and it tells you which fluids and how much.
Here is the link...http://www.amsoil.com/redirect.cgi?z...&page=appguide
If you have any questions please feel free to PM me or email me Gabe@syntheticlubestore.com
Ridin' Around is offline   Reply With Quote
Unread 05-13-2008, 03:15 PM   #5
Ridin' Around
For the trans...http://www.amsoil.com/redirect.cgi?z...storefront/atf
For the T-Case you can use the same ATF fluid listed above for the tranny. For the Diffs there are a couple of choices but the most popular is 75W-140 her is the link to it...http://www.amsoil.com/redirect.cgi?z...storefront/svo
Please let me know if this helps!
Unread 05-15-2008, 11:37 AM   #6
Shirai_Ryu
Straight from the manufacturer:
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION SPECIFICATION
FUEL TANK – Gasoline & Diesel 19.5 U.S. Gallons (74 Liters)****
ENGINE OIL
Engine Oil - with Filter - 2.4L 4.7L (5.0 qts.)
Engine Oil - with Filter - 3.7L 4.7L (5.0 qts.)
Engine Oil - With Filter - 2.5L/2.8L Diesel 6.0L (6.3 qts.)
ENGINE COOLANT
Cooling System - 2.4L 9.5L (10.0 qts.)
Cooling System - 3.7L 13.2L (14.0 qts.)
Cooling System - 2.5L/2.8L Diesel 12.5L (13.2 qts.)
POWER STEERING SYSTEM
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 545RFE 4.73L (10.0 pts)
O-haul Fill - 545RFE 13.33L (28.0 pts)
Service Fill - 42RLE 3.8L (8.0 pts)
O-haul Fill - 42RLE 8.3L (17.6 pts)
Dry fill capacity Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/AUTOMATIC/FLUID - STANDARD PROCEDURE)
TRANSFER CASE
NV231 1.4L (2.95 pts.)
NV242 1.6L (3.4 pts.)
MANUAL TRANSMISSION
NV1500 (Approximate dry fill or fill to bottom edge of the fill plug hole.) 2.3L (4.8 pts.)
NV3550 (Approximate dry fill or fill to bottom edge of fill plug hole.) 4X4 - 1.98L (4.2 pts.) 4X2 - 2.28L (4.8 pts.)
FRONT AXLE
186 FIA (Model 30) 1.24L (2.6 pts.)
REAR AXLE
8 1/4 2.08L (4.4 pts.)*
* When equipped with Trac-lok, include 118 ml (4.0 ounces) of Limited Slip Additive.
****Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
Shirai_Ryu is offline   Reply With Quote
