03to04 motor swap help - JeepForum.com
post #1 of 10 Old 06-01-2014, 02:06 AM Thread Starter
wvjeepman2014
i have a 2004 jeep liberty 3.7 i put a 03 model engine in it swapped the refluctor rings out and dropped it in hit the key fired right up the jeep will not take gas u try to throttle it it just bogs out well i checked all the coils put new plugs i put 3 new injectors in on pass side and now i noticed the 03 model injectors show diff from the 04 injectors would that cause it to not take fuel?crank censor cam censor and knock censor are all the same everything plugged up fine?can someone please help me please please please
wvjeepman2014 is offline
post #2 of 10 Old 06-02-2014, 08:13 PM
TwoBobsKJ
2003 KJ Liberty
Did you also swap out the cam tone ring on the right side cam? The cam ring is different from '04 to '03 just as the reluctor ring is.
If the cam ring is not the correct one the computer won't feed the spark and fuel to the proper cylinder at the proper time
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #3 of 10 Old 06-03-2014, 04:58 AM Thread Starter
wvjeepman2014
the tone ring as in the lil round ring behind the cam gear its self?
post #4 of 10 Old 06-04-2014, 10:03 AM
TwoBobsKJ
2003 KJ Liberty
The gear and ring are a single unit - so you replace the right side cam gear with one for your model year (can be from ANY model Chrysler product with a 3.7 from the same year as your original) or you can get one from engine-guru.com. Go to their website to get their number to call about getting the cam gear. I bought their kit that includes the reluctor gear, the cam gear and the EGR blocking plate when I swapped in a 3.7 from an '07 Dodge Dakota into my '03 Libby. The kit worked great and kept me from having to break down two engines just to get the reluctor and cam gears out of my original engine.
Hope this helps!
Bob
post #5 of 10 Old 06-04-2014, 03:00 PM Thread Starter
wvjeepman2014
i swapped out the ring on the cam gear its a lil wheel with little like windows in it and i swapped out the ring with teeth on it thats on the crank shaft also?it fires up and runs idles fine just will not take throttle?will a bad tps sensor cause it?
post #6 of 10 Old 06-04-2014, 07:16 PM
02blue
2005 KJ Liberty
I got a code when my TPS crapped out. Might check it anyway or the IAC.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline
post #7 of 10 Old 06-04-2014, 07:35 PM
02blue
2005 KJ Liberty
I wouldn't ignore the injector issue too. Did you put in 03 or 04 injectors when you changed 3 of them? Could be Cats or O2 sensors (upstream) fuel pump... seems like there should be a code for many possible issues.
02blue is offline
post #8 of 10 Old 06-05-2014, 05:21 PM Thread Starter
wvjeepman2014
i got a code i need to check n i put all 03 injectors back in it?i asked a guy at a local garage he doesnt seem to think the injectors being 03 would cause the issue?a bad tps would cause it?i was thinking run a fuel pressure test on it and a code scan?
post #9 of 10 Old 06-05-2014, 07:15 PM
02blue
2005 KJ Liberty
I would think it better to put the 03 injectors with the 03 computer but can't say for sure. The TPS should give you a code if that's it. Mine was all weirded out when my TPS failed.
Let us know what the code is.
02blue is offline
post #10 of 10 Old 06-06-2014, 03:16 AM Thread Starter
wvjeepman2014
ok 02blue i got a 04 jeep the computer and everything is 04 only thing o3 is the injectors...............i put a scanner on the thing i got a crankshaft camshaft position censor correlation code and tps sensor code and a injector cylinder 1 open circuit?does it sound like its out of time to u or whats this mean?
