03 valve cover gasket - JeepForum.com
post #1 of 4 Old 11-13-2013, 05:36 PM Thread Starter
KENRAY
Looks like I have as leaky passenger side valve cover gasket. Mechanic friend said its a rubber gasket shouldn't be bad just tighten the bolts. Since its rubber what causes it to fail? Can I just tighten the bolts?
KENRAY is offline
post #2 of 4 Old 11-13-2013, 06:19 PM
John317
Its a common problem, just buy new gaskets its not too hard of a fix. If you tighten the bolts down uneven you could damage the valve cover or if you tighten them too much you could break them off.
John317 is offline
post #3 of 4 Old 11-13-2013, 06:24 PM
tommudd
2004 KJ Liberty
Bolts will only tighten so much, only true way is to replace. Its not bad maybe 30 minutes to get your tools out/swap it and clean up
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #4 of 4 Old 11-15-2013, 07:06 AM
TwoBobsKJ
2003 KJ Liberty
What Tom said. There are spacers that prevent the bolts from being tightened past a certain point - if you try to tighten them down past that you're likely to break them. So you'd be compounding your problems.
Passenger side is the harder of the two sides to repair since the heater lines run over top of the valve cover, but once those and the coolant reservoir are out of the way it goes very quickly.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
