03 Liberty Oil Pan Removal Procedure - JeepForum.com
post #1 of 4 Old 04-17-2012, 06:47 PM Thread Starter
03NYLibSport
2003 KJ Liberty
Hello all, this is my first posting...and thanks in advance for any assistance you can provide. I bought my 03 Liberty at an auction last year and it recently started leaking oil from the oil pan which has rusted out badly - layers of the metal are flaking off. The maintenance manual says to remove the engine in order to remove the oil pan. Is there a "less involved" procedure to remove/replace the oil pan without having to remove the engine?
If so, please share the procedure and advise of any precautions / safety steps I should use...thanks.
03NYLibSport is offline
post #2 of 4 Old 04-19-2012, 08:23 PM
gjinc
removing the engine might be the easiest way
OIL PAN
DESCRIPTION
The engine oil pan is made of laminated steel and
has a single plane sealing surface. The sandwich
style oil pan gasket has an integrated windage tray
and steel carrier (Fig. 84). The sealing area of the
gasket is molded with rubber and is designed to be
reused as long as the gasket is not cut, torn or
ripped.
REMOVAL
REMOVAL
(1) Disconnect and isolate negative battery cable.
(2) Install engine support fixture.
(3) Raise and support vehicle.
(4) Remove front wheel assemblies.
(5) Remove skid plate (if equipped).(Refer to 13 -
FRAME & BUMPERS/FRAME/FRONT SKID PLATE
- REMOVAL)
(6) Drain engine oil.
(7) Mark adjustment cam position of front lower
control arm bolts.
(8) Remove front lower control arm bolts.(Refer to
2 - SUSPENSION/FRONT/LOWER CONTROL ARM
- REMOVAL)
(9) Disconnect LH tie rod.(Refer to 19 - STEERING/
LINKAGE/TIE ROD END - REMOVAL)
(10) Disconnect LH lower ball joint(Refer to 2 -
SUSPENSION/FRONT/LOWER BALL JOINT -
REMOVAL)
(11) Disconnect LH strut clevis(Refer to 2 - SUSPENSION/
FRONT/CLEVIS BRACKET - REMOVAL)
(12) Remove LH front axle(Refer to 3 - DIFFERENTIAL
& DRIVELINE/HALF SHAFT - REMOVAL)
(13) Remove front axle brace bolts.
(14) Remove front prop shaft.(Refer to 3 - DIFFERENTIAL
& DRIVELINE/PROPELLER SHAFT/
PROPELLER SHAFT - REMOVAL)
(15) Drain front axle.
(16) Using a transmission jack, support front axle.
(17) Remove axle bracket bolts.(Refer to 3 - DIFFERENTIAL
& DRIVELINE/FRONT AXLE -
REMOVAL)
(18) With RH axle still in place, remove front differential.
(19) Remove transmission oil cooler line bracket.
(20) Remove engine to transmission stiffening
bracket.
(21) Position Special Tool 8534 on fender lip and
align the slots in the brackets with the fender
mounting holes.
(22) Secure brackets to the fender using four M6 X
1.0 X 25 MM flanged cap screws.
(23) Tighten the thumbscrews to secure the
sleeves to the support tube.
(24) Secure the support tube in an upright position.
(25) Assemble the flat washer, thrust bearing,
hook and T handle.
(26) Using the M10 X 1.75 mm flanged nut supplied
with the support fixture, secure the chain to
the front engine lifting stud.
(27) Loosen engine mounts.
(28) Remove oil pan bolts.
(29) Seperate oil pan from engine.
(30) Move oil pan to one side, remove oils sump
bolt and windage tray bolts,
NOTE: Do not pry on oil pan or oil pan gasket. Gasket
is integral to engine windage tray and does not
come out with oil pan (Fig. 85).
(31) Move the oil pan and windage tray toward
front of vehicle and remove from vehicle.
REMOVAL - 4x4
(1) Disconnect Battery.
(2) Install Engine Support Fixture, special Tool
8534.
(4) Remove front wheel and tire assemblies.
(7) Remove engine to transmission structural
cover, (if equipped).
(8) Remove transmission oil cooler line bracket.
(9) Remove the front axle assembly from the vehicle(
Refer to 3 - DIFFERENTIAL & DRIVELINE/
FRONT AXLE - REMOVAL).
(10) Loosen both engine mount through bolts.
(11) Lower the vehicle.
NOTE: It is not necessary to remove the viscous
fan , or fan shroud, for oil pan removal.
(12) Raise the engine using Engine Support Fixture,
special Tool 8534, until the viscous fan almost
touches the fan shroud.
(13) Raise the vehicle.
(14) Remove the oil pan bolts.
(15) Separate the oil pan from the engine.
(16) Remove the (2) nuts and (1) bolt holding the
oil pump pick-up tube, and windage tray in place.
NOTE: It will be necessary to move the oil pan from
side to side to gain access to these fasteners.
(17) Drop the oil pump pick-up tube into the oil
pan, and remove the oil pan, pick-up tube, and the
windage tray, as an assembly, from the front of the
vehicle.
gjinc is offline
post #3 of 4 Old 11-24-2014, 10:47 AM
wayne66
how to r&r oil pan 02 jeep liberty 3.7
wayne66 is offline
post #4 of 4 Old 11-25-2014, 03:40 AM
AVR2
The procedure is as listed above. You have to support the engine from above and drop the whole front axle assembly.
AVR2 is offline
2003 , liberty , oil pan , removal
KK Liberty Front Bumper Removal diggerfreek KJ Liberty Forum 13 04-16-2015 08:28 AM
Jeep Liberty recall procedure for Lower Ball Joints Steven73 KJ Liberty Forum 20 07-20-2013 10:11 AM
2009 Liberty 3.7 l V-6 oil filter removal shotgunner KJ Liberty Forum 6 06-26-2009 11:16 PM
Jeep Liberty Diesel Removal... FastZFunMJ KJ Liberty Forum 1 05-20-2009 09:19 AM
2003 Liberty Front Windshield wiper replacement procedure Steven73 KJ Liberty Forum 3 11-27-2004 07:38 PM
