Quantcast '03 Liberty Clicking w/ Wheel Rotation - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > '03 Liberty Clicking w/ Wheel Rotation
Truck-Lite's New LED Headlamp SeriesNEW! Poison Spyder RockBrawler BFH Bumpers!Poison Spyder BFH Rear Bumpers
Old 02-29-2008, 01:04 PM   #1
BubbaJane
HELP! I have noticed this increasingly irritating "clicking" when my wheels rotate... ie: increases with speed, and slows down and stops when braking. I can't tell if it's front or back. It sounds as if "something" is hitting the tire(s). I have just had my front rotars (sp?) replaced, and had my ball joints replaced per recall. The result... CLICKING! Of course I'm hoping it's not serious... but I'm ready to lose my mind! Any ideas? Have mercy!
BubbaJane is offline   Reply With Quote
Old 03-07-2008, 12:55 PM   #2
gmctd
2005 KJ Liberty
Need to get the mech to recheck his ball-joint\brake work - if all ok, and 4wd, need to check the outer joints in the front half-shafts for dry\worn
96 Dodge 3500 CTD, unseemly unstock
If it's a Diesel thing, I do understand....
'05 CRD; INMOTION ST-II; EDGE Trail; Pricol Boost, EGT, Rail Press, Trans Temp; SEGR; Provent; Magnaflow;
2.5" Daystar f, OME r; Al's arms, Moogs; Ranchos; Rubicons, 2.55 Gy's; Suncoast T\C, Transgo
'06 Cummins lift pump module, Fuel Manager\Filter, Filterminder
Four in a row really makes it go
gmctd is offline   Reply With Quote
Old 03-08-2008, 03:11 AM   #3
Liberator
Before you bring it to service, have somebody stand outside the vehicle while you drive around in the parking lot to isolate where it is coming from.
Are you using snow tires? Could be a simple thing ie. check if you have a rock in your tire tread?
Liberator is offline   Reply With Quote
Old 03-11-2008, 09:19 AM   #4
john hitt
I had the same problem for weeks, and it ended up just being a loose hubcap rattling with each wheel rotation. Try taking them off and see if the sound goes away. If that's the problem, they're pretty easy to tighten.
john hitt is offline   Reply With Quote
Old 06-03-2010, 05:19 PM   #5
CG_Doc
2003 KJ Liberty
I have the same year model with the EXACT same problem. T-birdjunkie just recommended I tap on all the centercaps to see which one is loose. Sounds something like what john hitt is recommending. Let me know how it goes for you, cause it could help me as well. I'll let you know anything that is suggested to me.
CG_Doc is offline   Reply With Quote
Glock Forum
