02 Turn Signal Tail Light Wires to Splice for LED Load Resistor? - JeepForum.com
post #1 of 5 Old 05-08-2014, 11:55 AM Thread Starter
brendanc
2002 KJ Liberty
As the title suggests, I'm trying to find out if anyone knows which wires specifically are linked to the tail light turn signals?
The wiring harness has 5 or 6 wires, I believe, but I don't know which ones go to the turn signals. I need to splice into those to connect my load resistors so that I can install my LED turn signal bulbs, otherwise I get the dreaded hyperflash.
02 Liberty, 4" JBA Gold Lift
brendanc is offline
post #2 of 5 Old 05-09-2014, 09:00 AM
Billwill
2002 KJ Liberty
Can you not open up one of the rear plastic turn/stop/reverse/tail-light assemblies and physically see which color wires go to the turn signals?
Should be Brown/Red on the right and Dark Green/Red on the left!
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #3 of 5 Old 05-09-2014, 09:03 AM Thread Starter
brendanc
2002 KJ Liberty
I wanted to avoid disassembling the housings. Also didn't think that the wiring inside the housings would match the wiring harness
Thanks though!
brendanc is offline
post #4 of 5 Old 05-13-2014, 02:01 AM
Billwill
2002 KJ Liberty
Thanks though!
They generally keep the same wire colors for a particular circuit the same, all the way from the BCM for example, through a couple of connectors, maybe splitting up a few times until it gets to the end component.
Makes it quite useful for tracing when a voltage goes missing.....you measure wire Yellow/Black for example at its source and get voltage. Now you measure the same color wire at its destination and the voltage is missing. So now you go halfway until you find the break.
Billwill is offline
post #5 of 5 Old 05-13-2014, 03:46 PM Thread Starter
brendanc
2002 KJ Liberty
Yeah I double-checked the FSM and you were correct. I triple-checked with the audio function on my multimeter with each turn signal engaged. Beep beep beep beep!
Got everything sorted out and have 100% LED lights in the rear now.
brendanc is offline
