02 no crank no start - JeepForum.com
post #1 of 5 Old 11-19-2013, 05:41 AM Thread Starter
bulrokyj
I have an 02 limited with 180xxx miles. Turn key to acc and dash and idiot lights come on. Turn to start position and hear a click (from starter) and all lights on dash go off till I return key to run position.It wouldn't turn over. Pulled the starter and it works but no crank. Tried to put breaker bar on crankshaft pulley and I couldn't get it to budge. I didn't take spark plugs out so maybe that is why it wouldn't rotate. I'm gonna try that this week. I'm thinking the motor is toast but looking for other possibilities. Any help would be much appreciated.
bulrokyj is offline
post #2 of 5 Old 11-19-2013, 01:17 PM
2007LIB
2007 KJ Liberty
Battery?
If it ain't broke don't fix it.....Enjoy it.
2007LIB is offline
post #3 of 5 Old 11-19-2013, 01:50 PM Thread Starter
bulrokyj
Battery seems to be ok. Haven't put a meter on it or anything. Going to pull starter and have it checked along with the battery. I will update when I get that done. Thanks
bulrokyj is offline
post #4 of 5 Old 11-20-2013, 12:19 AM
Billwill
2002 KJ Liberty
With the spark plugs out you should be able to turn the engine with a breaker bar....unless something is horribly wrong
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #5 of 5 Old 03-25-2014, 03:53 AM Thread Starter
bulrokyj
Update:
Had a mechanic friend of a friend of mine tell me the motor is locked up. When you turn the key you can see the crank turn a little bit when starter engages. I haven't ever seen a locked up motor before but I didn't think it would move at all if it was locked. I don't really want to junk it but can't afford to swap the engine. Any ideas? Came to the experts here again to get advice on what to do. Thanks for taking the time
bulrokyj is offline
