02 Liberty. Nickle and dime to death. Heater Problem - JeepForum.com
post #1 of 13 Old 11-29-2007, 10:08 AM Thread Starter
knuckleslammer
2002 KJ Liberty
Here we go again. 70k on my 02 liberty. Last week oil pressure switch. This week heater problem. Heat works, AC works. Problem is it only blows out of defrost vents. Can't switch it to floor or vents.
Any ideas. This car is killing my family with nickle and dime and I need money for xmas.
Any help is appreciated.
Kevin
knuckleslammer is offline
post #2 of 13 Old 11-29-2007, 01:06 PM
merlinTec
merlinTec's Avatar
Hi
Does the cruise control work? Sound like an air leak
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 13 Old 11-29-2007, 01:19 PM Thread Starter
knuckleslammer
2002 KJ Liberty
Just curious, what does the cruise control have to do with it? I know there must be an explanation. Not sure, just got word from wife about this. I'll check and get back to you.
As far as an air leak. I called the dealer. They said sometimes it could be a cracked hose under the hood? So that said, does this system of switching vents work off some type of vacuum system rather than an electronic switch with motor type of thing?
Any help is appreciated. I would rather not spend another $200 at the dealer. Last week it was $200 for oil pressure switch.
Kevin
post #4 of 13 Old 11-29-2007, 01:24 PM Thread Starter
knuckleslammer
2002 KJ Liberty
She said it does not appear to be working but light comes on (cc light) but I then explained that you have to go over 30 I believe. I'll test it myself when I get home.
post #5 of 13 Old 11-29-2007, 02:18 PM
jeepjeepster
The cruise and the blend door(controls where heat comes out) both work off of a vacuum. Its kinda common and yes, the dealer was right about a hose being cracked.
Open the hood while the Jeep is running and listen for a hiss. The blend door seems to default to the defrost mode when it doesnt have a vacuum. Friend of mine had the same problem with his 1993 Cherokee.
jeepjeepster is offline
post #6 of 13 Old 11-29-2007, 08:02 PM
captainfarrell
Ok, the cruise control doesn't work. I listened for hisses with and without the blower motor on and with the engine on and off. I can't find any hiss and there are so many hoses I don't know what's what. Any idea what I'm looking for and where? Under the hood by the drivers side firewall is where I looked. Sorry for the double usernames. I was at work and couldn't remember this one at home. So, knuckleslammer is me as well. Mods can delete either one.
Kevin
captainfarrell is offline
post #7 of 13 Old 11-29-2007, 08:05 PM Thread Starter
knuckleslammer
2002 KJ Liberty
Kevin
post #8 of 13 Old 01-14-2008, 04:22 PM
AIRWOLFORD
2002 KJ Liberty
Jeep Liberty 2002
Kevin,
Vacuum balls tell the air where to go under the dash. Check your main
vacuum line coming from the motor just behind the glove box there will be a Tee in the line where it connects to the operator line for the outside air duct.
Stuart
AIRWOLFORD is offline
post #9 of 13 Old 01-14-2008, 05:00 PM Thread Starter
knuckleslammer
2002 KJ Liberty
Thanks man, 2 month too late though
I traded in the POFS and bought a Toyota Highlander. There's a reason American auto sales are plummetting and the consumer reports speak for themselves. I with I had checked them before I bought the Jeep and my last Jeep. Jeep sucks and can't make a decent vehicle. I've spent over $2500 in repairs for this 2002 SH*TBOX. Leaky transfer case, busted AC radiator or whatever it's called. Frozen caliper. I DON'T EVEN OFFROAD EITHER. JHFC, Imagine if I did what they do on the commercials? LOFL F- JEEP you guys can have them all to yourselves
post #10 of 13 Old 01-14-2008, 05:49 PM
jeepjeepster
10-4, you seem to be mechanically challenged so its ok. Now go figure out have many yen you just wasted.
post #11 of 13 Old 01-15-2008, 08:10 AM
nhcd538
Yeah Jeeps certainly aren't for people who can't do maintenance on vehicles. Enjoy your Toyota. If you or your husband need help installing an air freshener or something, look us up.
1999 TJ 2.5L AX5 NP231 D35/30 4.11's
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #12 of 13 Old 01-15-2008, 09:09 AM
x99j
obviously you haven't checked on the highlander either!!! link below
what highlander not recommended by consumer reports? fall from grace!!!
http://www.consumeraffairs.com/news0...ighlander.html
engine problems? no not in a toyota!
http://www.consumeraffairs.com/autom...ta_engine.html
sludge? no can't be? in a highlander?
http://townhall-talk.edmunds.com/dir.../.eea225d/5402
people have problems with highlanders? and vent in forums? no can't be?
http://www.toyotanation.com/forum/forumdisplay.php?f=83
you also forgot to add in the expense of the timing belt replacement on the 3.0L and the 3.3L. yep with water pump and seals over 1000 dollars especially from the dealer.
you are sadly mistaken when you think your days of spending money on auto's is over. i haven't owned one yet that didn't break and that includes my old camrys (not complaining just noting cars aren't free to operate)!
To combat the nickel dime syndrome you might want to 1) take better care of you auto's 2) stop living paycheck to paycheck. (so you can actually afford repairs) why? because repairing an automobile is almost always cheaper than replacing the car with another. good luck with your future. mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #13 of 13 Old 01-27-2008, 02:59 PM
79cherokee
Also, you bought a 02. Any vehicle bought in the first year of production seems to have stupid little problems. Seems as if it takes a year to figure out all the little gremlins. I hope your Toyota gives you what your looking for, but I know you will be shocked when it comes time for service and cost of replacement parts. Good Luck.
03 Liberty Sport 4x4 3.7 auto, stock
84 CJ7 2.5 4 speed , stock
79cherokee is offline
Heater fan not working in 2004 Jeep Liberty grossbeck KJ Liberty Forum 7 09-23-2009 03:09 PM
04 Liberty Heater Fan not working at all srushia KJ Liberty Forum 5 02-09-2008 07:58 PM
Liberty heater blows cold at idle eever45 KJ Liberty Forum 2 01-18-2008 03:56 PM
Liberty Heater/ac fan JAR01 KJ Liberty Forum 3 10-18-2005 06:37 PM
2002 Liberty Heater Question 20KJ02 KJ Liberty Forum 4 11-14-2003 04:12 PM
