02 Liberty Heat not working - JeepForum.com
post #1 of 5 Old 04-04-2013, 09:57 AM Thread Starter
res0n0xg
1994 ZJ
It's an 02 Liberty Sport, heat simply won't even turn on, what would be the process to check to see why not? Despite where the knob is set, it simply blows ice cold AC, nothing else.
Is this something super simple I'm missing?
res0n0xg is offline
post #2 of 5 Old 04-04-2013, 10:42 AM
tjkj2002
2002 KJ Liberty
Have you checked your coolant level?
tjkj2002 is offline
post #3 of 5 Old 04-04-2013, 10:49 AM Thread Starter
res0n0xg
1994 ZJ
coolant level looked fine in the tank, no overheating or anything, why?
res0n0xg is offline
post #4 of 5 Old 04-04-2013, 10:53 AM
tjkj2002
2002 KJ Liberty
Low coolant is the biggest reason for little or no heat.
Next step is to check the blend door actuator,it's electric unlike the mode doors which are run by vacuum.It's tucked way up top of the HVAC box,almost impossible to get to and dash removal is required to change.
tjkj2002 is offline
post #5 of 5 Old 04-04-2013, 12:31 PM Thread Starter
res0n0xg
1994 ZJ
Sadly that probably could be it, as it's not blowing luke warm, or mild, it's definitely activating the AC compressor still and blowing cold air.
res0n0xg is offline
