02 Liberty: Best Spark Plugs? - JeepForum.com
post #1 of 17 Old 06-26-2013, 12:15 AM Thread Starter
Spetznaz24
2002 KJ Liberty
I have a 2002 Jeep Liberty 3.7
Haven't changed the spark plugs in 4-5 years and want to do so now.
Which are the best plugs to use? I am thinking of Bosch Iridium Plugs.
Is there a a better alternative? Are the stock MOPAR OEM Plugs just as good?
Thanks
Spetznaz24 is offline
post #2 of 17 Old 06-26-2013, 01:39 AM
jbarthol
2005 KJ Liberty
Avoid iridium, and platinum like the plague. Go with copper core at least, at best use what is printed on the sticker. The techs who fix these engines, will be on shortly(usually),to tell of the problems iridium, and platinum has had with these engines. Also change them ASAP, the plugs should be changed every 30000 miles. After 4-5 years, if you drive like my family your well past that.
jbarthol is offline
post #3 of 17 Old 06-26-2013, 04:03 AM
tommudd
2004 KJ Liberty
Champion coppers best plug
4-5 years
They're cheap/easy to change
I do mine every 25,000
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #4 of 17 Old 06-26-2013, 06:58 AM
streetglideok
2005 KJ Liberty
I know I didn't just hear someone say bosch and spark plugs in the same sentence on a jeep site. Yeah Jbarthol called it, some of us would be on here to say do not use bosch anything that screws into the engine. Even euro trash is going to other brands. NGK coppers are the exact OE plug, and most KJs have the part number on the emissions sticker even. Some don't like NGKs, and use Champions. The 4.7L(sister engine) uses Champions as their oe plug. The only real difference is a slightly different heat range. Iridium and platinum plugs are good plugs, in the engines that require them. Gaps have to be different than copper plugs due to a difference in performance. Our engines run best on plain old cheap copper plugs, and take 20 minutes to change, every 30k. Not a hard job.
streetglideok is offline
post #5 of 17 Old 06-26-2013, 10:14 AM Thread Starter
Spetznaz24
2002 KJ Liberty
Thanks for the responses.
My local auto zone has the Autolite Copper Plugs. Would these be fine? Or should I try to find Champion or NGK?
post #6 of 17 Old 06-26-2013, 11:24 AM
DaveJKJ
2005 KJ Liberty
NAPA carries the NGK copper core plugs and I have been using those as they are OEM spec. Several changes with no issues. Just my experience.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #7 of 17 Old 06-26-2013, 11:44 AM
ppap
Exactly... The Liberty came stock with those and they work great. Why would you risk the unknown?!? I believe in buying OEM parts whenever possible.
ppap is offline
post #8 of 17 Old 06-26-2013, 12:20 PM
tommudd
2004 KJ Liberty
unknown??
Oh well
MUDD'S MOTORSPORTS
tommudd is offline
post #9 of 17 Old 06-26-2013, 07:58 PM
DarkSport11
2011 KK Liberty
NGK V-Power ZFR6F-11G (#6987) .044 Gap. Torque to 20 FT/LBS.
DarkSport11 is offline
post #10 of 17 Old 06-26-2013, 08:12 PM
tjkj2002
2002 KJ Liberty
Being you have a '02 also might want to recheck what you wrote as far as gap goes.
And it's 15lbs-ft,not 20.
tjkj2002 is offline
post #11 of 17 Old 06-26-2013, 09:23 PM
streetglideok
2005 KJ Liberty
First mistake, bautozone. They only carry a few brands of parts, and will tell you anything to get you to buy their garbage. Find a new parts store is your first order of business.
post #12 of 17 Old 06-26-2013, 10:19 PM
DarkSport11
2011 KK Liberty
Page 8I-3 of the 2002 Daimler Chrysler Liberty Service Manual states 20 ft. lbs. of torque for the 3.7L engine and 15 ft. lbs. for the 2.4L engine. It also states 0.042 in. for the spark plug gap. My local Jeep dealer's Service Dept. said 0.044 in. is the correct gap for the plugs.
post #13 of 17 Old 06-26-2013, 10:43 PM
streetglideok
2005 KJ Liberty
And typically, there is a note, to see the emission sticker for vehicle specific info. 0.040" is spec. Also, right out of Mitchell Ondemand5, 20ft-lb torque spec, and 0.040" gap. This info is taken from the OE.
post #14 of 17 Old 06-27-2013, 06:29 AM
DarkSport11
2011 KK Liberty
Double checked under the hood this morning and the sticker says .040, pulled them out and re-gapped them and torqued to 20 ft. lbs. as per spec. So much for listening to the service guy at the dealer. Never noticed the info was right on the sticker.
post #15 of 17 Old 06-27-2013, 07:01 AM
streetglideok
2005 KJ Liberty
Service writers usually have no clue, and are the last place to get info from. Lately I've seen service guys tell anyone all sorts of BS that comes in or calls with a question.
