02 liberty 4cyl. 2.4l spark plug location/ Pics are great!! - JeepForum.com
post #1 of 7 Old 01-17-2012, 05:44 PM Thread Starter
lildube4226
2002 KJ Liberty
Hey jeep family/ cyber mechanics,
I have been diagnosing a few current problems with my Liberty. I am throwing an engine code, with the help of some other members I have decided to switch out my spark plugs and start solving the issue from their. Correct me if I am wrong, but this should correct a cylinder misfire in cylinder 4, correct?
That being the case I have no idea where my plugs are, I assume there near the four coils that run off from each cylinder. How do I access these spark plugs? Any tips or information I should know about swapping them? Thanks everyone. All pics + information on this will be an enormous help.
Scott
lildube4226 is offline
post #2 of 7 Old 01-17-2012, 05:54 PM
tjkj2002
2002 KJ Liberty
The 2.4 gasser uses one coil pack and 4 spark plug wires.Just follow the plug wires to the spark plugs.
Don't forget to change the plug wires also when changing the plugs.If there is any oil in the spark plug tubes(oil will be on the wire boots) you need to chnage the valve cover gasket and tube seals,common misfire cause in those types of engines.
tjkj2002 is offline
post #3 of 7 Old 01-17-2012, 06:08 PM Thread Starter
lildube4226
2002 KJ Liberty
I see the four coils and I can pull them off, after I pop the coils off where do I go from here?
post #4 of 7 Old 01-17-2012, 07:10 PM
tjkj2002
2002 KJ Liberty
There is only one coil on the 2.4 gas engine.From that one coil are 4 spark plug wires.Follow the wires to the valve cover,pull the plug wires up out of the valve cover and the tubes is where the spark plugs are.
tjkj2002 is offline
post #5 of 7 Old 01-17-2012, 08:18 PM Thread Starter
lildube4226
2002 KJ Liberty
is there any links to a diagram of this?
post #6 of 7 Old 01-17-2012, 08:51 PM
streetglideok
2005 KJ Liberty
The plugs will be right on top, in the center of the valve cover. I strongly suggest, since you are a little inexperienced, you get someone to help you out. Not knowing what you are doing may cause more issues, like a stripped spark plug hole, broken plug in the head, etc. Then you will be in really deep doo doo.
streetglideok is offline
post #7 of 7 Old 01-20-2012, 11:39 AM Thread Starter
lildube4226
2002 KJ Liberty
I appreciate it man thanks alot for the help
cylinder misfire , help please , ignition coil , spark plug
Spark Plug Issues - 2006 Liberty spta97 KJ Liberty Forum 8 10-07-2010 07:59 PM
'05 Liberty Spark plug and coil change bieakma KJ Liberty Forum 8 12-07-2009 11:09 AM
Spark Plug gap for liberty '03 (3.7) bulltrout21 KJ Liberty Forum 4 08-31-2009 09:37 AM
04 3.7L Liberty MTX NV3550 Fill Plug Location and Socket Type/Size viperflyer KJ Liberty Forum 1 11-22-2008 05:32 PM
4cyl. 5spd Liberty burning plugs u0179187 KJ Liberty Forum 0 10-20-2008 08:50 AM
