02 KJ, aftermarket hitch install Q's - JeepForum.com
post #1 of 5 Old 07-15-2012, 08:55 PM Thread Starter
Durango_USMC
2002 KJ Liberty
I'm installing a Curt hitch on my 02 KJ sport. Does anyone know the size of the bolts that go into the nutserts in the frame chanel? The size I'm getting is 12mm-1.75
I just want to double check before I send a tap up there to clean out the threads.
Durango_USMC is offline
post #2 of 5 Old 07-15-2012, 09:57 PM
tjkj2002
2002 KJ Liberty
Yep M12x1.75,make sure to use only grade 10.9 bolts that are 40mm-45mm in length.
tjkj2002 is offline
post #3 of 5 Old 07-15-2012, 10:08 PM Thread Starter
Durango_USMC
2002 KJ Liberty
The ones curt sent are 8.8 is that better or worse? The tap has done an excellent job on the nutserts so far, but the last one is tricky as the tap is too long to fit between the exhaust pipe and the frame chanel, any suggestions?
post #4 of 5 Old 07-16-2012, 05:35 AM
tjkj2002
2002 KJ Liberty
Unless the hitch is just for looks I'd be buying grade 10.9's.For that one hole have someone grab the tail pipe and pull it towards the right side of the KJ to make room.
tjkj2002 is offline
post #5 of 5 Old 07-16-2012, 02:48 PM Thread Starter
Durango_USMC
2002 KJ Liberty
Thanks for the tip TJ. I ended up using a 2x2 to offset the exhaust pipe enough to run the last tap.
Aftermarket lights on '06 KJ...How to install? BobFromCO KJ Liberty Forum 12 12-16-2014 12:04 AM
How hard / $ is it to install a hitch? daOwenator KJ Liberty Forum 2 07-21-2009 07:12 AM
Aftermarket Radio Install babes66 KJ Liberty Forum 6 07-12-2009 11:48 PM
Aftermarket Hitch from Dealer? rmnoonan KJ Liberty Forum 9 03-06-2006 04:15 PM
Hitch install xtarheel KJ Liberty Forum 3 07-25-2002 11:21 AM
