02 Jeep Liberty only blowing hot air - JeepForum.com
post #1 of 4 Old 06-08-2014, 04:18 PM Thread Starter
Kimiko
2003 KJ Liberty
I don't know what the problem is at one point the line was cold and was and still is full with freeon and still wouldn't blow cold air only hot. I did some research online thought it might be the accumulator, bought a new one and replaced it now the line is hot and now it's still only blowing hot. Can anyone help me figure out what the problem is. Everything is running I just have no idea what the problem could be as to why it isn't blowing cold air and why the line went from cold to hot.
Kimiko is offline
post #2 of 4 Old 06-10-2014, 02:22 PM
olliehopnoodle
1982 FSJ Cherokee
Which line?
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #3 of 4 Old 06-10-2014, 02:28 PM
oldfamilyguy
So the compressor clutch is engaging?
oldfamilyguy is offline
post #4 of 4 Old 06-10-2014, 04:25 PM
remmons
If you had replaced the accumulator, what did you do with the old Freon? Did you let it discharge into the atmosphere? You didn't mention that you had recharged the system after installing the accumulator. If you didn't then that is your FIRST step. But if you did, did you put in ENOUGH R-134A Freon into the system? Your do-it-yourself kit gauge should read about 35-45 PSI at 75-85 Deg Fahrenheit (ambient temp), but consult with the installation instructions (or your service tech) on what your pressure should be.
Robert.
remmons is offline
