The Bus Jeep Registry
Previous Jeep Commander Next Jeep
The Bus
Email Bookmark Print
fuzzy94
New Milford NJ
Jeep Information
Year:2006
Model:Limited
Engine:5.7 Hemi
Transmission:M-B W5A580
Transfer Case:Quadra-Drive II NV245 transfer case
Suspension:2" Rough Country Suspension Lift
Tires:265 70 17
Wheels:Stock Limited Chrome
Armor:None
Accessories:Rear Entertainment System
Future Modifications:Light Bar, Bull Bar, Safari Rack
My baby, a work in progress
None
Login Or Register To Post Comments
cwolfe
View cwolfe's Jeep
11-11-2012, 06:24 PM
tire size with lift
Hi I noticed your tire size and I was wondering if you had to do the 2 inch lift or was that just what you wanted to do. I'm a little new to lifts, and I want to put on the same size tires and rims that you have. I was thinking of doing a front end leveling kit. Do you know if that would work?
fuzzy94
View fuzzy94's Jeep
11-13-2012, 09:16 AM
Its a two inch Rough Country Lift. I believe that a leveling kit should allow enough clearance to allow for the 265 70 17s, however the upper ball joint bolt will need to be cut to prevent contact with the larger tire. Heres the link for the lift I used http://www.roughcountry.com/jeep_commander_2.html
