Limited Jeep Registry
Previous Jeep Liberty Next Jeep
Limited
Email Bookmark Print
njgasman
Montclair
Jeep Information
Year:2004
Model:Liberty
Engine:3.7L 6 Cyl
Transmission:Auto
Transfer Case:242 Select Trac
4WD lever is stuck and will not engage. Mechanic tells me that the problem is, not the internal parts, but the transfer case itself. He says jeep redesigned the case because it had problems causing the shifter to bind. Has anyone else had the engagement problem and does anyone know if Jeep actually did redesign the case. Thank you for your consideration and information
None
