New to diesels Jeep Registry
Previous Jeep WK Grand Cherokee Next Jeep
New to diesels
Email Bookmark Print
harleybush
Jeep Information
Got a 07 jeep Grand Cherokee Limited w/3.0 CRD Diesel and Quadra drive II last fall. Finally got some suspension and lift done. Added Bilstein 5100's all the way around w/OME medium springs.
added a couple of inches, leveled it out and ride is much firmer. Oh yeah, right after I got it it needed tires and found a complete set of 2014's in 18" with nearly new Toyo AT's so I've been needing to add some lift for clearence and do the pinch weld mod. Finally got a round tuit. Changed oil a while back and went with Mobile ESP, not knowing any better i filled it to the full mark and its been leaking ever since (no leaks before and the mileage was 160k at change, now 168 and due for another change. So anyway, glad to be here, seems like lots of good info although I have not seen an answer as to why no fender flares are available for the WK while they are out there for everything else. I'll attempt to add a pic or two later, I am on the computer at work right now.
None
