Wj new edition... 2000 jgc 4.7 np249 Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
Email Bookmark Print
mississippiwj
Senatobia
Jeep Information
Hey folks, first post and new member here. Just thought I'd give y'all a run down on what I have done to my wj. First I got the jeep with a busted transfer case for $1k. Put another $1500 in it for transfer case, tires, DS conversion to dbl cardone . Then put it in shop because of front dif howl while driving. Another $1500 for all new timken bearings, stabilizer( due to bent shaft ) brakes, valve cover gaskets, and alignment. Would have done it most of it myself but didn't have the time or a press for the pinion bearings. I painted all my trim and front and back bumper rustoleum satin black( it made a huge difference on how it looks). I ordered a el cheapo bull bar off eBay and put on. Previous owner had put a lift on it , and said its 4" but I'm not sure about that. Today I went to the local pull a part and got a 160 amp alt off of a 03 durango. Installed.
I got fuel injectors from same durango that have 2 holes. I'm going to put those on if I can find new o rings from the zone or o reilys. Also picked up a trans fluid cooler off a 03 jgc. Started getting the wood grain trim for the inside. And last got wire mesh for grill to do to.
None
