Go Back JeepForum.com > Jeep Registry > WJ Grand Cherokee > Stockkkkkkk
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Stockkkkkkk Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
Stockkkkkkk
Email Bookmark Print
bwatson88
Jeep Information
Year:2004
Model:Grand Cherokee limited
Engine:4.0
my jeep stalls when going into reverse... ii read a post that said it could be my belt tensioner causing this? not real sure... how can i tell if my belt tensioner is bad? i glanced at my haynes manual and it says to look to see if arrow lines up with bolt. well mine isnt like that....on mine, it has 2 lines then a 1/4" over 1 line. then on back side it has a line. none are matching. is that a sign of a bad tensioner? i can post pics if you dont understand what im talking about. just lmk.. thanks
None
Login Or Register To Post Comments
redneckpen
View redneckpen's Jeep
06-20-2013, 12:07 AM
vacuum?
Have you looked at the vacuum system for leaks?
jeepinjeepin
View jeepinjeepin's Jeep
06-23-2013, 08:38 PM
The belt tensioner will have absolutely zero effect on stalling in any gear. Well, if your battery is weak and the alternator is slipping while trying to make amperage at idle... Does it run fine at idle in drive? With just a touch of throttle will it stay running in reverse?
