removing abs system Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
removing abs system
Email Bookmark Print
WJDesertRacer
Poway
Jeep Information
I already run with my abs fuse removed so the abs does not activate. My next concern is what the effects are of removing the abs valve body and computer and just running new brake lines from the master cylinder to axles. I'm currently swapping axles and using tc output shaft for speedo reading. Will removing this part disable speedo completely? Or will I be fine with out it being that its not a dd and only street legal for more trail access.
None
