Jeep Grand Cherokee Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
Jeep Grand Cherokee
Email Bookmark Print
wornout99
Jeep Information
Adding my 2002 Jeep Grand Cherokee
None
Login Or Register To Post Comments
wornout99
View wornout99's Jeep
01-13-2014, 11:08 AM
Cruise Control Turning Off
My cruise control would drop off every once in a while. It finally started every time I turned it on. Would not light up until I restarted the engine then immediately drop off.
I read about it on this site and ended up trying the AutoZone 13.99 brake pedal sending unit fix. IT WORKED. Easy to remove the sending unit from the Jeep body, hard to get the wiring harness keeper clips pushed in so I could remove the wiring and plug it in to the new unit. After using a sharp object to get the keepers recessed, the wiring harness came out of the old unit. Easy to put the new unit in place, just follow the enclosed instructions. Fixed the problem.
The only difference from the posts of how to do this with an AutoZone part is the part is $15.02 because the Peoples Republic of California add tax.
