Hasbrobayes Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
Hasbrobayes
Email Bookmark Print
Hasbrobayes
Broadalbin
Jeep Information
Year:2004
Model:Jeep grand cherekee limited
Engine:4.7l
Transmission:545rfe
Transfer Case:4 wheel drive
I am haveing issues with fourth gear slipping I have replaced the line pressure sensor the solinoid block and installed the recommended shift kit with new filters and ATF+4 trans fluid plus did relearn program and still the same with p1790 code coming up now fault immeditly after shift
None
Login Or Register To Post Comments
47WJCORY
View 47WJCORY's Jeep
06-22-2013, 08:55 PM
Sounds to me like you might have some clutches slipping did you find any material in the pan
Hasbrobayes
View Hasbrobayes's Jeep
06-22-2013, 10:23 PM
I was hoping not to hear that I'm wondering is it possible it could be the speed sensors
Hasbrobayes
06-22-2013, 10:26 PM
Is anyone out there know if a bad speed sensor would cause slipping in 3rd and 4th gear
