Notices
Grand Cherokee Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
Grand Cherokee
Email Bookmark Print
Turboguypdx
Portland
Jeep Information
Year:1994
Model:Laredo
Engine:4.0
Transmission:Automatic
Transfer Case:Selec-trac
I joined the forum because I was researching the PCM capacitor problem. After looking around the forum a bit, I knew there was much more help available on various issues. I am the owner of an Oregon based Subaru repair and performance shop. I can spot good threads and this was full of them. Also, I could see the very knowledgeable people were willing to help others. I hope to get more involved in the very near future. Also, don't hesitate to ask me Subaru questions!
None
Login Or Register To Post Comments
gratefuldude
View gratefuldude's Jeep
04-22-2012, 02:07 PM
What kind of problems are you experiencing with the PCM? Reason I ask is that i have been having intermittent problems with my 04 GC Laredo 4.0. Sometimes it will go into limp-in mode and @ 10 codes will show up referring to various electrical related issues with different sensors. I had them tested separately and they are fine. After a quick flick of the keys to reset things performance is back to the norm. Any thoughts on this or have you experienced similar problems?
Turboguypdx
View Turboguypdx's Jeep
04-22-2012, 02:49 PM
My 94 jgc 4.0 has been a problem child for a year. Last month I scored a reman pcm from ebay. I had already replaced the capacitors in the first one but still had erratic no start issues. The second pcm has eliminated all no start problems. My jeep has stalled twice and not restarted with this Ebay pcm. It happened in the exact same place and wouldnt restart for a half hour. I had the tools with me to swap pcm and still no start. I read an excellent thread here about the crank sensor absorbing heat which then causes it to stop pulsing. Ive replaced the crank sensor and it hasnt stumbled yet. I will retrace my route where it failed twice in the exact same spot. Its a mountain road that gains 1000ft elevation in two miles. Wala heat build up on the crank sensor.
Turboguypdx
05-24-2012, 07:14 PM
Since I replaced the crank sensor, the check engine light has come on several times for the alternator field not switching properly. Then all that went away and it hasnt stumbled for two weeks.
ThreadThread StarterForumRepliesLast Post
Grand Cherokee CRD Wings WJ Grand Cherokee 1 01-28-2012 08:37 PM
Grand Cherokee ragyabuamra WJ Grand Cherokee 2 10-04-2011 01:19 AM
Grand Cherokee Grandbeaver WJ Grand Cherokee 0 11-19-2010 08:24 PM
