Notices
Blacked out WJ Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
Blacked out WJ
Email Bookmark Print
Dustin0718
Corvallis
Jeep Information
Year:2001
Model:Grand Cherokee
Engine:V8 4.7L
Transmission:545RFE
Transfer Case:NV247 Quadra-Drive
Suspension:5.5 inch Rock Krawler X Factor
Tires:Falken Rocky Mountain 31.5/75R16 (35")
Wheels:Unknown brand
Accessories:Aftermarket grille, Dual halo headlights/ fog lamps, LED tailights
Future Modifications:Bull bar, roof rack 40" LED light bar, Suggestions???
Bought this recently in January 2014 and have since poured several thousand into it. The Black Grille, Head/tail/fog lights were all done within the last two weeks. New Falken tires a month ago. Have a hitch and Black 3" nerf bar steps yet to install. I've replaced all window and hood hydraulics, a few mechanical pieces (valve covers seals, u-joints, tie rod ends, thermostat housing, etc.), as well as the heater module (its hooked up to a toggle switch so it only runs on high speed air, new one will fix this once i remove toggle) and coin tray/ash tray and heated seat switches. The instrument cluster was also switched out and will be doing the clock spring to repair the horn and cruise control (it broke during lift install). It also has a k&n cold air intake installed. Hoping to do much more in the coming months after i get caught up on installing everything i already have. Any "wow-factor" type suggestions? let me know!
black , grand cherokee , lift , rock krawler , wj
Login Or Register To Post Comments
