Warhead Jeep Registry
Previous Jeep ZJ Grand Cherokee Next Jeep
Warhead
Email Bookmark Print
tramatizer
Jeep Information
Year:1993
Model:Zj
Engine:4.0
Suspension:Long arm long travel 5.5" lift
Tires:35x12.5
Need help. Can't find a upgrade possibility for a radiator. Looking for a way to put a three row all aluminum radiator with electric fans. Or something else that would be a good upgrade. What are my possibilities.
None
Login Or Register To Post Comments
tramatizer
View tramatizer's Jeep
09-23-2013, 06:00 PM
1993 grand cherokee zj. 4.0.
tramatizer
09-23-2013, 06:07 PM
[Please help zj radiator question.
tramatizer
09-23-2013, 07:03 PM
no one knows.
wrangler4991
View wrangler4991's Jeep
10-03-2013, 10:41 AM
What is in your way of putting the three row radiator in?
katmccabe
View katmccabe's Jeep
10-10-2013, 09:41 PM
Can't crank over my 93 grand cherokee 6 cylinder
Can anyone help? I was thinking there was some water in old gas, tank was low about an 1/8 to 1/4 dummy me. Cranks but won't turn over. Did code said 341? what's that mean, only thought codes were 2 numbers. Is it code 34 and 41 on list? if so would they answer my question why won't turnover? trying to pinpoint is it water in my gas? or is it that solenoid circuit code? gettin confused. Trying to narrow it down. Battery pretty weak also if that helps anyone. Help! thanks. I do not want to have to drain gas tank. Isn't fuel filter right in it instead of easy to check and change if water got in there? Now the code says 124 this morning, but heard codes before 96 jeeps not reliable. 124 came up with battery hooked up to charger btw. Maybe not fuel problem, crank sensor? or dirty distributor cap. Still cranking, heard fuel pump also, but won't turnover. Think battery doesn't have enough juice? Suppose i should start at air filter intake and spray starter fluid to see if fuel right? Help! thanks
tramatizer
10-24-2013, 03:58 PM
I couldn't find any one who makes a three row for my jeep and I didn't want to have a custom one made. So I ended up getting a standard one and added the new electric fan. I works great and it's an easy upgrade to add.
