Merc Jeep Registry
Previous Jeep ZJ Grand Cherokee Next Jeep
Merc
Email Bookmark Print
froggy68
Bristol
Jeep Information
Year:1996
Model:ZJ Grand Cherokee
Engine:5.2L V8
Help please! I have replaced the battery, starter, and alternator in my Jeep recently. When I turn the key over, I hear a very faint click one time and nothing else. I can use a screwdriver on the posts of the starter solenoid with someone turning the key and the Jeep fires up no problem. Any useful information about what could be the problem will be greatly appreciated!
None
Login Or Register To Post Comments
CenCalCurt
View CenCalCurt's Jeep
04-26-2014, 01:30 PM
Should check the ground from battery to body or engine
froggy68
View froggy68's Jeep
05-24-2014, 09:30 AM
Ground
I've checked that too and it's a good ground. Still problem persists and I'm not sure the next step
CenCalCurt
05-27-2014, 10:39 AM
Ok, next step would be to check the ignition switch, there is a rod that connects to the key switch and and travels down into an electrical switch, usually attached to the steering column under the dash. I had a car that the electrical switch burned and wouldn't accept the start position.
CenCalCurt
11-10-2014, 10:36 PM
Did you figure it out?
