Hiker's Jeep - 5.2, 4x4 Jeep Registry
Previous Jeep ZJ Grand Cherokee Next Jeep
Email Bookmark Print
webwalker
Marietta
Jeep Information
Year:1996
Model:Grand Cherokee Laredo
Engine:5.2
Transmission:44RE
Transfer Case:249
Front Axle:30
Rear Axle:44A
Axle Gear Ratio:3.73
Suspension:Standard
Tires:P225/75R15 OWL All Season Tires
Wheels:15X7.0 Sport Aluminum Wheels
Future Modifications:swap 249 for 242 transfer case
Miles: 206,000
Used for taking hikers to the mountains and hiking the A.T.
Issues:
1. Front Drive Shaft - Blew out - Removed it
2. Front CV Joints - Replaced
3. Front Wheel Bearings - Replaced
4. Rear Wheel Bearings - Replaced
5. Transmission- would not go into overdrive -
Adjusted front and rear bands
Trans Valve body: Replaced Governor Pressure Sol., Pressure/Temp Sensor, Converter Clutch Sol., Overdrive Sol., Accumulator Piston Spring (broken), wiring harness and case connector.
6. Replace Trans Speed Sensor
7. Loud rear differential - investigating
8. Front Drive Shaft rebuild - ordered parts
9. Driver's door lock actuator - ordered parts
10. Dash lights issue - soldered connectors on switch
None
Login Or Register To Post Comments
