Coolant Leak - Thoughts... Jeep Registry
Previous Jeep ZJ Grand Cherokee Next Jeep
Email Bookmark Print
specia1k
Jacksonville
Jeep Information
'98 JGC 4.0 has developed a slow coolant leak. With 190K miles I went ahead and replaced the water pump and thermostat. Still I have a small coolant leak. I removed the plastic shroud around the radiator/fan for more visibility. The leak is on the passenger side of the radiator. Coolant pools up on the frame cross member just below the radiator. It does not appear to be coming from the drain plug. No coolant visible or by touch on drain plug.
Thoughts on where the coolant could be leaking from?
None
