Notices
Broken Drivers Door Jeep Registry
Previous Jeep ZJ Grand Cherokee Next Jeep
Broken Drivers Door
Email Bookmark Print
neilv1
new bedford
Jeep Information
Year:1997
Model:Grand Cherokee Limited WJ
Engine:5.2 V-8
Hey, I am brand new looking for some help. I have owned my 97 Grand Cherokee v-8 since it was two years old. Still runs awesome but just ran into a problem that I could seriously use help with. The other day while getting into the Cherokee I tried to close the drivers door and it just kept bouncing back open. Upon checking it out well, I see that the steel part of the door that hold the mounting screws for the latching mechanism have actually broken and torn and the mechanism is almost now loose inside the door. I can get it to stay closed for the life of me and have been looking around for a drivers door an cannot find one. Does anyone know if they make an aftermarket plate for this problem and what is it called? Is it something that has to be welded in or can it be drilled and screwed in? Any help would be greatly appreciated. Thanks.
None
Login Or Register To Post Comments
jessiellover
View jessiellover's Jeep
10-27-2013, 08:31 PM
Pictures would be beneficial.
DocRoberts
View DocRoberts's Jeep
11-01-2013, 07:58 PM
Hi,
I had the same problem on my '98 and have seen it on five or six ZJ since. The first thing you need to do is replace the hinge pins and bushing. The bushing have worn out and the lock doesn't line up like it should. Any auto parts store carries the kit. There are full instructions on this forum to do the job. I used a small steel plate on the lower two bolts of the latch to shore up the lock. You will need to cut down the shoulders of the bolts to get them to fit thru the plate, but it works like a charm. My email is chopperrob68@gmail. I can send you a photo if you need one
Rob
