post #1 of Old 11-17-2013, 12:29 AM Thread Starter
zjgunter54
Big Change (Advice)
Hey everyone. I'm new to this but I finally got my 98 zj that I have been wanting since I was 15. I'm 19 now. I just took out a $3000 loan. I am getting RC 4' inch lift. New steering stabilizer. 15 inch rims and federal couragia 33x12.50s. Also new joints all around and kn air intake. Let me know if I am missing anything! Do I need a aftermarket track bar or sway bar?
zjgunter54 is offline
post #2 of Old 11-17-2013, 12:42 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Track bars, front and rear longer sway bar links, brakeline extensions...
D3<!L!>3D
S8NNG8 is offline
post #3 of Old 11-17-2013, 10:58 AM Thread Starter
zjgunter54
The RC kit on Morris4x4 pretty much covers all over that. Brake line relocation bracket and sway bar links.
post #4 of Old 11-17-2013, 03:54 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
The brakeline relocation bracket that came with my kit was a joke. It requires you to rebend the hard lines, which I didn't think was a very smart idea so I never used it.
D3<!L!>3D
S8NNG8 is offline
post #5 of Old 11-17-2013, 04:16 PM Thread Starter
zjgunter54
So what do I need to get to replace that?
post #6 of Old 11-17-2013, 04:42 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I've been wanting to get the right thing myself. There are extensions that thread onto the hard lines and give you more slack for flexing. I haven't even researched them all that much, but I'd guess you would order the length based on how much lift you have.
D3<!L!>3D
S8NNG8 is offline
post #7 of Old 11-17-2013, 06:59 PM Thread Starter
zjgunter54
Well extensions are like $120 dollars.
post #8 of Old 11-17-2013, 07:07 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
What I did is located where the brake lines come to a T-block bolted to the axle tube. Pull the bolt, lift the T-block, and put the bolt back in without it. This has worked for me for almost 2 years now. It would get you by until you can afford the extensions. Plus it's given me more slack than the bracket would have.
D3<!L!>3D
S8NNG8 is offline
post #9 of Old 11-17-2013, 07:10 PM Thread Starter
zjgunter54
Okay I gotcha. I'm just ready to order all this stuff and gotta make sure I get the correct stuff.
post #10 of Old 11-17-2013, 07:36 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Ok, hold up! What I just explained about the T-block is what I did on my XJ. I just went out and looked at my ZJ and I don't think that's gonna work for you. You may want to wait and see how your brakeline bracket is gonna work for you. The T-block is there on the ZJ but the ABS line bracket is in the way of allowing slack. If the bracket is bogus, you want to look into brakeline extensions sooner than you wanted to.
D3<!L!>3D
S8NNG8 is offline
post #11 of Old 11-17-2013, 07:39 PM Thread Starter
zjgunter54
Yeah I know. I will be getting everything and getting a professional to install it.
post #12 of Old 11-17-2013, 08:24 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
No! Unless there's no chance you'd have somewhere to do it, you should do it yourself. You'll learn how simple of a design you have to work with. It'll teach you what to check when things are wrong, and you'll know how to fix it. Plus you'll have way more love and respect for YOUR JEEP!
D3<!L!>3D
S8NNG8 is offline
post #13 of Old 11-17-2013, 08:30 PM Thread Starter
zjgunter54
That's the problem. I don't have anywhere to do it. Much less proper equipment.
post #14 of Old 11-17-2013, 08:42 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
A set of SAE & metric wrenches, a $20 socket set from Walmart, and a couple screw drivers and you'd have almost everything you need. The only specialty tool I can think of is a pickle fork for the TRE on the frame side of the track bar.
D3<!L!>3D
S8NNG8 is offline
post #15 of Old 11-17-2013, 08:49 PM Thread Starter
zjgunter54
But I don't have jack stands or any of that stuff.
You may not post new threads
You may not post replies
