General Information
Name
MJ Comanche
Year
1988
Model
comanche pioneer
1988 MJ Comanche comanche pioneer
Modifications
Suspension
original stock.
Wheel and Tire
stock too big!
Engine
4.0l
Transmission
4spd auto
Future Modifications
im sure at least 1 of everything.
Accessories
haha maybe when it runs rite
Recovery Gear
none
Armor
none
Axle Gear Ratio
idk.....
Rear Axle
it is also there
Transfer Case
n/a (2wd)
Front Axle
its there
Information
i traded a family member a 9mm pistol for this truck. it kept overheating on him after he replaced the heater core. he ran it so hot for so long it needed a head gasket and new freeze plugs. he was done with it. he had already put a new exhaust system on it, a new harmonic balancer, and valve cover gasket.
so... i do work on this beast. thinking its a quick head gasket kit and 5 freeze plugs away from running great. then i (with a lot of help from this very website) replaced: all the injector "o" rings, new spark plugs, new wires, new battery, new knock sensor, new crankshaft position sensor, new water pump, new front calipers (both sides), new front break hoses (both sides), new master cylander, new break booster, new speedometer cable, and burped this wonderful closed cooling system. now it runs and stops great.:cheers:
