Notices
Jeep Comanche Jeep Registry
Previous Jeep MJ Comanche Next Jeep
Jeep Comanche
Email Bookmark Print
thomas0153
Ashland
Jeep Information
Year:1991
Model:Base
Engine:4.0L
Transmission:Auto
Transfer Case:N/A
Wheels:31/10.5R15
Accessories:CB
Future Modifications:In Progress
I am the proud owner of a 1991 Jeep Comanche. My comanch is my pride and joy. Unfortunately, she is not running right now. I purchased a new battery a few months ago (Optima deep cycle) and apparently my alternator went out. I have been running on battery power (unknown to me) and she would not start (did not even click when key was turned). We jump started her and she turned over and ran okay. I recharged the battery when I got her home and she ran great. After a few starts (yesterday) she would not even click (again) when I turned the key. I, again,recharged the battery (which took awhile this time) and ordered a replacement alternator. The problem is that she does not do anything (not even a click) when I turn the ignition key, even with a fully recharged battery. Any ideas?
None
Login Or Register To Post Comments
Kanola
View Kanola's Jeep
04-02-2012, 01:16 PM
Just a guess, maybe bad alternator if the bats not recharging, couldnt be starter if the thing turns over when jumped or after fresh recharge like your saying yeah? Just sounds like alternator not charging to me but im no ASE, try run a test on your alternator volt drop an such
Kanola
View Kanola's Jeep
04-02-2012, 01:18 PM
Did you add anything electrically like winch, amps, subs, etc? If have to many loads the alternator cant power it all and it will drain your bat
jees-comanche
View jees-comanche's Jeep
05-13-2012, 08:57 PM
Check your starter. Mines doing the same but its the wiring thanks to the previous owneres neglect. But trace your wires. Are the soaked in oil or loose? If so, its probably the solution to your problem
ThreadThread StarterForumRepliesLast Post
Comanche lsmurphy MJ Comanche 0 07-30-2011 11:41 PM
comanche comancheeman MJ Comanche 0 04-24-2011 03:16 PM
Comanche MJ wmotor348 MJ Comanche 0 03-19-2011 08:48 PM
comanche fernjohn MJ Comanche 0 01-10-2010 08:43 PM
Comanche davemci MJ Comanche 0 11-29-2009 05:28 PM
