Notices
Ole Blu Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Ole Blu
Email Bookmark Print
OleBlu95
Jeep Information
Year:1995
Model:Cherokee
Engine:4.0L
Suspension:Rough Country 3"
Tires:31 10.5 15 All Terrain
Wheels:Stock
Armor:Glock 9
Recovery Gear:Cell phone
Accessories:Hoola girl on dash
Future Modifications:Roof Rack
Hellloooooooo!!!!! I just finished lifting a 95XJ so I today is the day I join the Forum! Installed RC 3". 2 things. (1) whats the best way to eliminate vibrations from drive train?? and what are bump stops and do i need them? Leave some tips or experience, thanks!
None
Login Or Register To Post Comments
YoureverydayXJ
View YoureverydayXJ's Jeep
01-11-2013, 07:50 PM
First step to eliminating them is identifying them. Obvious place to start, your pinion angle(s) will be off if you didn't adjust with lift.
Bumpstops are rubber, polyurethane, etc. that are placed strategically to limit axle up-travel. Stock XJ placement is inside front coils, and bolted to uniframe above rear axle. If you are running oversized tires, extended bumpstops will keep them from contacting (destroying) your fenders on compression. So, if you are running larger than stock tires, and haven't clearance-cut your fenders you should run extended length bumps.
OleBlu95
View OleBlu95's Jeep
01-12-2013, 09:05 PM
Ok I will check angles before I drop the t case (which WAS solution #1). Upon acceleration are vibrations and even more the farther throttle. For the time being, about a week, would this cause any damage? W/O 4wd?
