Go Back JeepForum.com > Jeep Registry > XJ Cherokee > Need HELP!!!!!!
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Need HELP!!!!!! Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Need HELP!!!!!!
Email Bookmark Print
sccarr54
San Jose
Jeep Information
Year:1995
Model:Cherokee XJ
Engine:4.0
Transmission:auto
Hey everyone, I'm new on here and need all the help I can get. So here it is. My son has a 95 cherokee Xj with a 4.0 straight 6 in it. Here's the problem. He was driving and the thing started to just die. It's like you just shut down the key. So I started doing research and spending alot of money. I have changed the coil,wires,plugs,cap and rotor first and nothing. Next I read that the CPS could be the problem so I changed that and nothing. Next I changed PCM and again nothing. So I changed the MAP sensor and the TPS sensor along with the camshaft position sensor and still nothing. I even went as far as trying a different CPS. I'm stuck and need help!!! ANYONE PLEASE.
None
Login Or Register To Post Comments
sccarr54
View sccarr54's Jeep
03-21-2014, 07:13 PM
No one on here has any clue?
irish82bikes
View irish82bikes's Jeep
03-22-2014, 01:47 AM
What does it do when you turn the key and try to start it?
sccarr54
03-24-2014, 06:01 PM
So when I turn the key it starts and will run for awhile but then it just cuts out again. This weekend I changed the starter and the IAC sensor. Ran for awhile and then same thing. I just don't get it. The only thing I haven't changed is the o2 sensor,but would that not have the vehicle have spark?
JeepinJeremy
View JeepinJeremy's Jeep
03-24-2014, 06:04 PM
Did you even check fuel pressure before you started dumping money into it? Just cause the pump comes on doesn't mean its good.
irish82bikes
03-24-2014, 10:01 PM
Sccarr text or call me I work 3-11 so before or after those hours would be easier and faster. 608 343 7068
draxxusxj
View draxxusxj's Jeep
03-25-2014, 06:03 AM
Fuel filter
Not sure if this will fix your problem but had an old CRX that would do this..... changed the fuel filter and it fixed it. Would run fine until it warmed up and then would die and not start until it cooled down again. Hope this helps
sccarr54
03-27-2014, 06:33 PM
Yes, That was the first thing that I checked and yes I changed the fuel filter as I was doing that process.
psycokid94
View psycokid94's Jeep
07-04-2014, 05:02 PM
KISS (keep it simple stupid)
Check that the fuel is actually getting to the engine, and if so how much
-Fuel pump
-sending unit
-filter as said above
-fuel rail pressure
-Fuel regulator
-injectors
Also check the ignition switch itself. And also another thought check the alternator and batter, and all of your ground wires.
I am not saying to spend a bunch of money replacing all of this stuff, but just check it to make sure those things are functioning properly.
Just some thoughts if you haven't found the problem yet.
nicco196
View nicco196's Jeep
07-26-2014, 12:09 AM
Is it running hot when it shuts off or normal running temp? And when it dies do dash lights stay on?
nicco196
07-26-2014, 12:12 AM
And I would have thought CPS at first. Pretty common prob on an xj. A lot of times they have thermal failure and work again after it cools.
