Notices
Jenny Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Jenny
Email Bookmark Print
96CherokeeS
Jeep Information
Year:1996
Model:Cherokee Sport
Engine:4.0 Liter In-Line 6 cylinder engine
Transmission:AW4 Automatic Transmission
Transfer Case:New Process NP231 Command-Trac, part-time only, 2.72:1 ratio with low range NP231 has the following settings: 2HI, 4HI, N, 4LO
Front Axle:Dana 30, high pinion, reverse cut, 297x/760 universal joint, 27-spline axleshafts
Rear Axle:Dana 35, c-clip, non-ABS.
Axle Gear Ratio:3.55:1
Suspension:coil spring front suspension with a leaf spring rear suspension
Name's Matt, getting pics up soon.
None
Login Or Register To Post Comments
